Oil pooled in throttle body
Old Mar 26, 2011 | 10:09 PM
dhatcher's Avatar
I decided to follow the DIY today on cleaning the throttle bodies because the idle has been a bit rough at stop lights since I bought the car.
I went to clean the passenger side TB first and when I pulled it off I noticed there was a tiny amount of oil pooled on the backside (connecting to the plenum). Maybe a teaspoon or less. The driver's side TB did not have this same occurrence.
Is it anything to worry about? Should I be taking it to a dealer and telling them what I saw so something can be fixed under warranty (car still has remaining factory warranty)?
Thank you all!
Old Apr 3, 2011 | 02:41 PM
RemmyZero's Avatar
well i expect you would see a little bit of oil and residue but a teaspoon sounds like alot to me....although to be fair that could have been collecting since day 1 and you never knew it. i would take it apart again in 1k-2k miles to see if you have any accumulation. if you see it coming back quick then report it to infiniti right away.
- Bob
Old Apr 3, 2011 | 03:45 PM
cwepruk's Avatar
I just did it at 40k and there was a touch of oil. I think this is pretty common in almost any car as the oil gets into through the PCV system. A lot of turbo guys use catch cans and the oil will settle there and stay out of the intake.
Old Apr 4, 2011 | 09:22 AM
Triton3.5's Avatar
Exactly right!!! My 2000 Ford Lightning, ( as did all of em) would get much oil in intake, and behind throttle body, ended up running breathers on valve covers, like the old days lol... amoung other things to try and stop the pvc, system from pulling oil up......
Old Apr 4, 2011 | 04:10 PM
dhatcher's Avatar
yeh it's been suggested I try replacing the pcv as well. so im going to give that a whirl and see what happens next time at oil change.
Freeman186
Sep 6, 2023 10:07 AM
sales@czp
Suspension-Vendor
26
Nov 6, 2017 03:04 PM
CV35Driver
Sep 15, 2015 05:09 PM
esotericrider
Northern California
Sep 10, 2015 02:28 AM
Chadwick Arnold
Sep 9, 2015 02:59 PM
