Trans is starting to piss me off..would a grounding kit help?
Old Oct 8, 2011 | 10:15 PM
Anton_Chigurh's Avatar
Trans is starting to **** me off..would a grounding kit help?
It has always been like this since i bought the car i believe. Or at least the past 6 months. When the car is cold it downshifts pretty hard. From 2nd to first when coming to almost a complete stop..the car will lurch forward a good amount. The first stop you make you have to come to slow down very very slowly if you don't want it to lurch...but after 15 min of driving it almost all of that lurching goes away. Also when it's cold and you go and doing a rolling stop at a stop sign and go and hit gas as you are rolling..it lurches a good amount. Again only when car isn't really warmed up yet. When it's warm it's almost non existent.
ATF fluid still has a red/pinkish tint to it and isn't burnt at all. Just annoying is all. Would a grounding kit solve some of this?
Old Oct 10, 2011 | 09:46 PM
anyone?
Old Oct 11, 2011 | 03:02 AM
JDMPenn's Avatar
Someone said from another thread earlier that their dealership person told them that was normal in the beginning until the fluid warms up in the transmission. Apparently, the fluid is supposed to be pretty rough when its not in operating temperature and gets more smooth from a little bit of driving. Sorry, I don't have any definite answers but maybe if you changed your fluid. Not sure how many miles since your last change.
Old Oct 11, 2011 | 11:16 AM
Once it is warm it is much smoother....maybe i will do a partial exchange. The fluid looks fine however
Old Oct 11, 2011 | 11:25 AM
RemmyZero's Avatar
hey Anton, a grounding kit can't hurt....it may help resolve some issues, but it's not really possible to say for sure. i will say that my tranny, whether warm or cold, has been exhibiting odd behavior. sometimes it will shift quite rough and i don't know why. i still need the software update performed, which im hoping to do in a couple weeks.
Old Oct 11, 2011 | 11:47 AM
What software update?
Old Oct 11, 2011 | 12:16 PM
SxExCx's Avatar
If the response of the tranny is being affected by a matter of temp or time, it is most likely a mechanical issue. If this is the case, extra grounding will not fix the problem.
Old Oct 12, 2011 | 06:48 PM
Mine seems to be affected by temp and or time. Knowing my luck with this car it's a tranny issue. I am going to try a partial fluid exchange to see if it helps at all even though fluid looks fine.
Would be kinda nice to find out that it's causing my vibration issues as well..but it doesn't feel like a tranny vibration as in the whole cabin isn't shaking or shuddering like at 40 mph
Question to you guys..may be a stupid one...does the tranny fluid in these cars heat up when you warm the car up for say 3-5 min? Or does it warm up faster when changing gears down the road
Old Oct 12, 2011 | 07:02 PM
gary c's Avatar
This does sound like a mechanical issue if your fluid is full and in good shape. I usually suggest Red Line synthetic fluid swap since it's not effected by heat but I'm not sure that's your answer.... You might what to discuss your issue with a reliable trans shop.
Gary
Old Oct 12, 2011 | 07:09 PM
Gary
The only fluid i will put in is the Matic-S..don't trust anything else as i have heard putting other brands in cause it to have a rough shift
Wonder how many qts i will get from a partial..6 at the most?
What do people use for the TC fluid?
Old Oct 12, 2011 | 08:07 PM
vqsmile's Avatar
You need to drive it to warm up the fluid. Idling in your driveway does nothing.
Old Oct 13, 2011 | 06:22 PM
Where is the cheapest place to get Matic-S? I need to do a full fluid exchange here...
Old Oct 13, 2011 | 06:51 PM
vqsmile's Avatar
Getting lazy again there, eh Anton?
http://www.g35parts.com/Nissan-Matic...9mp-mts00p.htm
Old Oct 13, 2011 | 07:03 PM
Canadian's Avatar
Canada, eh?
You can also use Amsoil ATF, many people here in Vegas, including myself used it and had to issues. No rough shifting or anything, and I got it cheaper. Amsoil ATF meets or exceeds the requirements for matic J and S.
Old Oct 13, 2011 | 07:24 PM
I was just wondering if anyone found it cheaper out there. I know Ebay has 12 qts for about 110
