Getting driveshaft balanced
Old Apr 8, 2012 | 01:17 PM
Anton_Chigurh's Avatar
How big of a job is it. Expensive?
Old Apr 8, 2012 | 10:34 PM
kool_yaar's Avatar
A while back my friend had his f150 drive shaft balanced from a local shop that specializes in it and it didnt take too much time, dropped it off in the morning and picked it up within a couple of hours and we werent even first in line. Cost him ~$60 cash i think after some haggling but this was 3-4years ago so not sure what the rates would be like today but d guess between $80-140 ??
Old Apr 8, 2012 | 10:37 PM
kool_yaar's Avatar
^ btw that rate was just to re-balance without any removal or installation charge since we did that ourselves in his garage, well he did the work while i helped with some hammering power
Old Apr 9, 2012 | 01:07 AM
seymore4's Avatar
m56
Why would you even think that you needed to balance it????
Old Apr 9, 2012 | 01:18 AM
AARONHL's Avatar
Still have shaking steering wheel?
Old Apr 9, 2012 | 09:46 AM
Short answer yes. Going to try a few things ans see what happens and this is one of them. I think i can take it out myself and bring it somewhere...just need to find some info on taking it out... but not sure if anyone has done it before
Old Apr 9, 2012 | 05:39 PM
salvador312's Avatar
I really hope this is IT!!! Good luck!
Old Apr 9, 2012 | 06:04 PM
AARONHL's Avatar
I find it hard to believe your drive shaft is messed up. I would think the bottom of your seat would be vibrating with a bad drive shaft, not your steering wheel.
Drive down to CT so I can take it for a test drive Hahaha
Old Apr 9, 2012 | 07:58 PM
Seat vibrate as well as the wheel. Seems like the whole chassis vibrates almost but not 100% on that. So hard to pinpoint it. Where in CT? By Foxwoods? i am there a lot LOL
Old Apr 9, 2012 | 07:59 PM
AARONHL's Avatar
Only on the highway? I replaced a compression rod and that help highway vibrations.
I'm on the other side of CT, just South of Hartford hahaha
Old Apr 9, 2012 | 08:05 PM
Yeah i don't venture to that side...ever..only the side with the casinos
How much did the compression rod run you..where you get it from? Maybe ill replace those first
Edit: i see you have a 1st gen
Old Apr 9, 2012 | 08:51 PM
AARONHL's Avatar
It was about $200 for the driver's side off eBay.
It's definitely difficult to diagnose vibrations over the internet, as well as clunking or popping noises...do you have any clunking noises?
I don't know what was looked at, but if you feel feedback through the steering wheel, I would start at the outer tie rods, inner tie rods, and check to see if the steering rack is leaking. Are any ball joints leaking? Either on the compression rod, steering knuckle, or upper control arm. You may have to take each arm off and jiggle the ball joint.
Never heard of a drive shaft issue on any G.
Can you also post your alignment numbers.
Old Apr 9, 2012 | 08:52 PM
AARONHL's Avatar
Has the car been in an accident? Did you notice the vibrations all of a sudden or over time? Are your brake rotors warped?
Old Apr 11, 2012 | 10:02 AM
I have a whole thread in Suspension and i have typed all of it over and over again. I won't bore you but everything has been checked by 3 mechanics. All say fine. Infiniti said they feel it..but nothing is wrong with the car..WTF. They have been there since day 1 when i bought it
It's weird..i can't find any parts online for my 07 G35x. all i am seeing is 03-06
Old Apr 11, 2012 | 10:47 AM
AARONHL's Avatar
That's messed up if Infiniti cannot find the problem.
