Spark plug recommendation
for a 2007 G35X intake exhaust tuned driven hard daily would you guys recommend getting different spark plugs? other than oem?
All i can find is stock replacement iridiums denso and ngk. thinking of going with ngk, but also found the ngk ix but those seem to be only for the DE motors.
any suggestions?
any suggestions?
any suggestions?
any suggestions?
NGK laser iridium
I was looking like crazy for that answer here but no one gives a straight answer or the why. I went ahead and bought the NGK Laser Iridium, they are expensive but in very pleased. Cost me 120 at O'Rileys lol.
New owner here. I bought a 2008 G35 this week with 107,000 miles on it and did a bunch of DIY stuff on it including brake fluid flush, oil change, and ATF drain and fill and spark plugs. I bought Denso FXE22HR11 Iridium Long Life Spark Plugs for about $10 each after coupons and discounts at Advance Auto Parts. Now for the bad news, when I got to the plug on the passenger side closest to the firewall I noticed that the plug threads were wet with what looked like fresh oil. From the searches I have done it sounds like the valve cover needs replacing. The car is running fine and not throwing any codes. What have your experiences been with this, do I have to replace the valve cover or can I just periodically go in and check that plug and mop up any oil that is in there? Thanks
.02
Diode Dynamics
Accessories-Vendor
39
Nov 30, 2021 02:28 PM
