Various Torque Specifications
Hello! I have recently taken apart my G and gone throughout the process of replacing the slave cylinder, rear main seal, and pilot bearing! Now that these things are out of the way, I need to reinstall everything, including the flywheel, clutch pressure plate, transmission bolts, as well as the driveshaft! Now, I have used the search function and gone through Nicoclub's website and I was unable to find anything on specific torque specifications. The furthest I got was "tighten to specified torque." What specified torque? Could I be looking at the pictures all wrong?
Thank you, and sorry if I seem clueless!
https://www.nicoclub.com/infiniti-service-manuals
RMS will be section EM, AT or MT for the transmission bellhousing, PR for the propeller shaft, RFD for the rear differential.
Be sure to verify on each exploded drawing either your values are inch or foot lbs.
