steering column issue (motorized)
Old May 29, 2007 | 04:56 PM
Altersys's Avatar
I'm going to be taking my car into the dealership to get this repaired under warranty but I was wonderiong just for my curiosity if anyone else has this problem:
at every start, after the steering wheel/column has zipped into place, when I first lay my hands on the wheel and apply downward pressure, the steering wheel clicks down about five millimeters in my hands, to a lower position. Apparently, the column isn't properly "locking" into position in the vertical plane, until downward pressure is applied. After doing that, the column remains fixed and doesn't jiggle at all. However, this happens with EVERY start in the exact same way each time.
Anyone else have/had this problem? Thanks..
Old May 29, 2007 | 05:20 PM
CalsonicVQ's Avatar
I have the same issue. If I pull down hard enough on the steering wheel or accidentally knock the steering wheel downwards it will do exactly as you described. But 99% of the time, I just start the car and begin driving without putting any downward force on the wheel, it won't do it and doesn't bother me.
Old May 29, 2007 | 05:27 PM
timn99's Avatar
Yes, have noticed this as well on a few occasions when I pulled down on the top of the steering wheel to assist in getting out of the car. It budges just very slightly as you mentioned, but it is noticeable.
Old May 29, 2007 | 05:28 PM
Altersys's Avatar
have either of you had the car inspected for this?
seems like a potential safety issue if the lock completely fails....
Old May 29, 2007 | 05:33 PM
CalsonicVQ's Avatar
Very good point. I will definitely notify the dealer during my next scheduled maintenance. I don't like the car taken apart if it's not necessary, but you're right, it could be a serious safety issue.
Wonder it's somehow related to this http://www.infinitihelp.com/Ownershi.../ITB07-008.htm
Old May 29, 2007 | 05:46 PM
suby01's Avatar
so did you talk to the dealer and did they say or do anything about it yet? mine does the same
Old May 29, 2007 | 06:43 PM
Altersys's Avatar
who?
i have not yet. i've mentioned it to them but i'm not taking it in until next week sometime.
Altersys's Avatar
that's for cars equipped with the manual adjustment, not the motorized one.
Old May 29, 2007 | 07:10 PM
ChemGuy's Avatar
I wonder if re-teaching your steering wheel position would make a difference... I haven't seen this issue on mine. I'm thinking it might be possible that the position you picked might be right between two positions and you are able to force it down to the next one. Might be worth a try to re-teach it to a slightly different position and see if it changes anything. If it fixes it, I wouldn't worry about it. If not, I would definitely take it in to be looked at.
Old May 29, 2007 | 07:23 PM
Altersys's Avatar
i doubt it. it's not a "stepped" system. the motions are completely analog, so the locking mechanism should be as well.
regardless, you may be correct. but I don't want to "garage diagnose" a potential safety issue. my life is worth more than that...
Old May 29, 2007 | 09:20 PM
suby01's Avatar
i tried that nothing still does the same thing as it comes down locks into positon after i press on the steering wheel down moves down a bit maybe 1/16 inch.
Old May 29, 2007 | 09:46 PM
justpete0's Avatar
Yep, exact same problem. The dealer put a new steering column on order last week after investigating this problem. They apparently tried to tighten something up as it moves less now but they intend to replace the assembly.
Old May 29, 2007 | 10:07 PM
B L U E S L A T E's Avatar
Honda Accord
I am experiencing the same problem with my car...
Though I will be mentioning it to the service department tomorrow when I take my car in for the maintenance.
But please do post for any updates from the dealers... I'd like to get it fixed as well...
Old May 29, 2007 | 10:17 PM
suby01's Avatar
yes im going to dealer on sat, but youll get there before me, so if you can post updates.
Old May 29, 2007 | 10:34 PM
terrycs's Avatar
Yes, I noticed this on my car as well. Only when the steering column is initially moved into position. It would probably be fine if I didn't use the auto steering adjust during start up.
