Autozone and Synthetic oil
Old Jun 14, 2007 | 08:55 PM
rphman's Avatar
Question Autozone and Synthetic oil
does anyone have an item number or something that i can have the local autozone to order the elusive oil.....
so i know this has been discussed numerous times and there probabky is no right or wrong answer on what oil to use...
but i would like to change oil every 7500 miles....
when should i change over to synthetic?? how many miles?
should i change the oil in the g before the 3750 and if so when and what oil should i use and what weight??
what oil filter should i use?? Fram or K&N or what brand??
Any help or input would be greatly appreciated.....
Wade
Old Jun 14, 2007 | 08:59 PM
redlude97's Avatar
if you are looking for the german castrol, there is probably none left anywhere, its been discontinued for months. Mobil 1 is an okay synthetic, and so its pennzoil platinum if you are using it for nonextended drain intervals.
Old Jun 17, 2007 | 01:19 PM
rphman's Avatar
found some 0w30 castrol at autozone
i bought 14 quarts of 0w30 castrol from germany at autozone today...
now i have the oil...when should i change the oil in the infiniti?
What mileage?
What oil filter????
Thanks
Wade
Old Jun 18, 2007 | 08:58 AM
CarNutz's Avatar
What mileage?
What oil filter????
Thanks
Wade
Read the manual.. there are different maint schedules to follow depending on your driving habits. Filters are basically all good these days.. some have synthetic elements that filter better.. K&N, Wix are popular amongst car enthusiasts.
I use Mobil-1.. I plan on changing it every 5 to 7K miles depending on my driving situations... More hwy driving = longer change intervals. So the answer to your question depends on the type of driving you do..
Old Jun 18, 2007 | 01:39 PM
max2k1's Avatar
Whatever oil you decide to use NEVER, EVER EVER use a Fram oil filter.
Maybe there is one good fram filter model out of 20 .... I wouldn't ever screw on a fram to the G !!!
The OEM filter is pretty good .... so is Mobil 1, Pure One and Amsoil EAO line.
Old Jun 18, 2007 | 01:47 PM
jclit's Avatar
Care to elaborate?
Old Jun 18, 2007 | 01:53 PM
max2k1's Avatar
Originally Posted by jclit
Care to elaborate?
Google Fram filters ... you'll see
Bottomline -- Fram equates to a cheaply made filter - using it is asking for trouble.
Old Jun 18, 2007 | 10:01 PM
sloppymax's Avatar
the stock filters are not much better. anything with cardboard endcaps should be skipped if you want quality. check out napa gold, k&n and purolator pureone to name a few. this is borrowed from 6mt and is from 04 but is still relevant.
6mt.net discussion of oem nissan filter
Old Jun 18, 2007 | 10:04 PM
izmir41500's Avatar
G35driver Addict
i just got my oil changed at the dealer. 10w30 mobil1 synthetic with a mobil1 oil filter. they recommend 4k.
f22raptor
Mar 18, 2016 08:50 AM
prinny
Nov 22, 2015 11:07 PM
mbe32
Nov 13, 2015 11:09 PM
9tray turbo
Sep 29, 2015 10:22 PM
