20x9.5 +34 Will This Work In The Rear
Old Nov 29, 2007 | 05:05 PM
07 G35S Sedan's Avatar
Just curious if in fact a 20X9.5 +34 will work in the rear for an 07 G35S Sedan.
Let me know the pros and cons. Any feedback is welcome.
Thanks!
Old Nov 29, 2007 | 06:20 PM
g35_6gear's Avatar
With a +40 and a 9.5" rear, I can barely clear and that's with Eibach springs. I think with a +34 you will have an issue.
Old Nov 29, 2007 | 07:53 PM
Based on your picture you're most likely correct. BTW what size tire are you running?
Old Nov 30, 2007 | 01:59 PM
heyitsalex's Avatar
I have 19x9.5 with a 36 offset in the rear. the wheels stick out 5mm. It's so barely noticeable. No rubbing issues but I think that if you're running 20's, it really depends on what size tires you're running. I'm using 275x35x19 which is a pretty high tire wall.
Old Nov 30, 2007 | 02:07 PM
UltimateGee27's Avatar
Thanks!
40-45MM WILL DO
Old Nov 30, 2007 | 02:36 PM
Can you provide pictures?
Old Nov 30, 2007 | 03:10 PM
g35_6gear's Avatar
275/40/zr18
Old Nov 30, 2007 | 03:12 PM
g35_6gear's Avatar
here's pics with my 20x10's
Rears are 20x10 +44ish offset, 275/30/R20 Nitto 555
Old Nov 30, 2007 | 06:56 PM
heyitsalex's Avatar
its in the pictures thread. title is IP with a 3" lift kit.
not too good pictures. took some yesterday. should transfer to computer soon.
Old Dec 6, 2007 | 06:16 PM
heyitsalex's Avatar
pics with a +36 offset in the back
more pix here:
https://g35driver.com/forums/media-share-v36-sedan/191321-man-i-love-my-car-i-love-i-really-do.html
Old Dec 6, 2007 | 06:34 PM
Very nice! Looks pretty much flush with a +36 offset. Do you think it's possible to stuff a 285 in the rear with a +47 offset.
Old Dec 6, 2007 | 11:18 PM
G35Trippin's Avatar
I think TerryCS has 20X10 +48 with 285
Old Dec 6, 2007 | 11:23 PM
ttrank's Avatar
Grocery getter
6mm is only 1/4" past the +40's. I would bet they will clear.
Old Dec 6, 2007 | 11:32 PM
arent we glad the 07's come with the rear fenders already rolled from factory!
Old Dec 7, 2007 | 01:16 AM
Tim- I recall you had a set of Volk GT-C 20x9.5 +47 in the rears on your 1st Gen sedan. So you think a 285 will fit without any problems on my 2nd Gen sedan with the same wheel spec?
rezendvous420
May 31, 2020 01:26 PM
vitamin.v
Nov 7, 2019 06:10 PM
Kz_Ed
19 Inch
Oct 16, 2015 10:32 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
