VDC and SLIP light on
Old Jun 17, 2008 | 07:54 AM
  #46
bmfgsxr's Avatar
ive had this issue for a long time now, but just havent had the time to bring it to the dealer.. i get the slip, vdc, and brake light (emergency brake warning light). when you guys say a new brake switch are you refering to the emergency brake switch, or the brake pedal switch? im at the point of needing rear pads now, but this issue has been going on for 10k miles already. i am bringing it in next week though.
Old Jun 17, 2008 | 08:29 AM
  #47
TIRE_SMOKE96's Avatar
I had this problem, turned out one of my brake lines had a leak. A nut wasnt tight enough so every time I pressed on the brakes a little bit would leak out. so after a couple of months lights would come back on. Hope that helps.
Old Jun 17, 2008 | 04:10 PM
  #48
cdmorenot's Avatar
it happened to me when i did my brake retrofit. the hardline going into the g37 caliper wasn't tight enough so i lost all my brake fluid. check your brake fluid level
Old Jun 18, 2008 | 06:50 AM
  #49
bmfgsxr's Avatar
thank goodness for message boards. i would have been pissed if i brought my car in and went through the inconvenience of all that just to top off my brake fluid.. yep, just topped off the brake fluid and no more lights.. thanks
Old Aug 15, 2008 | 12:26 PM
  #50
Deezflip's Avatar
blaah....just when i thought i've been experienced every G35 complaint mentioned in this forum, this just happened to me this morning while down-shifting to 4th and WOT.
I'm about to check my brake fluid and pads.
Old Aug 15, 2008 | 01:34 PM
  #51
tg1234's Avatar
It maybe happened because your pads worn out.
tg
Old Aug 21, 2008 | 10:06 PM
  #52
ar9080's Avatar
mine does that when i turn the VDC off and spin the tires like in a doughnut, but it always goes away.
Old Sep 3, 2008 | 12:35 AM
  #53
BillE7448's Avatar
VDC / Slip / ABS
I have had a similar occurrence just this past weekend. Received a VDC SLIP ABS warning light on my dash. Called the service department who asked me if the car was driving okay. I said yes and said I would bring it in after the long holiday. Well, car completely crapped out on me in the middle of nowhere and had to be towed back. Oil all over the trunk of my car. Thought it was the differential, and was told today the whole differential had to be replaced. Seal was replaced a week ago and obviously wasn't the problem. They "think" it is a faulty weld or something. We will see what happens.
Just before this happend I noticed my breaking not being as strong and also a dip in my gas milage. Anyone have similar issues?
Old Nov 28, 2008 | 12:38 AM
  #54
Richard Su's Avatar
Hmmm..I just had this issue this morning when I did some mountain driving~ couple of hard corners. First the "Slip" light flashes and then stays on. I pulled over and restart engine and it was fine.
Then I continue driving and did some hard corners and this time "Slip" came on and "VDC off" comes on also. I restarted the engine and it went away.
My brake fluid is at max level, never touched it since I had the car. The brake pads are also pretty new.....
already over warranty and heard from everyone that infiniti dealers have terrible service so never want to bring the car to them...
unlike lexus or acura they fix it for you even after warranty expires =.=
Old Nov 29, 2008 | 10:37 AM
  #55
chairman25's Avatar
I hate the "nanny" (VDC) and turn it off often when I drive.
It does go on if you "work at it".....
I have the 35xS and have had zero issues while driving with the VDC off. If I corner too hard, the all wheel drive gives a little "assist" no muss, no fuss, after all awd is not just for snow and lousy weather.
Old Nov 29, 2008 | 11:34 AM
  #56
tg1234's Avatar
Yeap, awd keeps you in controll without vdc. I turn off the vdc even winter too.
tg
Old Nov 29, 2008 | 07:09 PM
  #57
Jp17's Avatar
Cool fixed for now
I too had the same problem with the 3 lights being on. After reading what the infiniti help forum, I topped off my brake fluid and the lights have gone out! I'd definitely try this fix first before ever taking it to the dealership.
Old Dec 2, 2008 | 04:50 PM
  #58
crashnburn's Avatar
why dont u guys scan ur car when u have the codes on... i just tgot all 3 lights(vdc, abs, and slip) when just driving in normal 20-30mph traffic... i felt a glitch in my brake pedal a few times b4 they came on... i had a scanner with me and scanned the brake system and got code p1108 left front speed sensor... i then drove bout 2 more miles and lights went off...
only had a scanner in my car cause i just got s/c and been throwing lights and having a few problems
Old Dec 2, 2008 | 04:59 PM
  #59
056MT14's Avatar
I've had this happen to. I've only noticed the "slip" light come on after doing serious donuts. Never knew why, but the light DOES go off with a restart. Weird.
Old Dec 3, 2008 | 11:08 PM
  #60
neo2000x's Avatar
Your brake fluid is low. I've had this happen as well. Search and you'll find more info on it.
