CF Error? HELP!
Old Jan 22, 2008 | 04:39 PM
KulG35's Avatar
CF Error? HELP!
So I just bought a CF and put one small folder of .mp3 on it. When I put the CF in it's says "no audio file" why is it doing this? I have under 512 of music and all .mp?
Thanks!
Old Jan 22, 2008 | 05:22 PM
max2k1's Avatar
Thanks!
I think the G can only read one folder deep.
So if you have a deep folder hierarchy with the files in the end, it won't work.
Try moving all the files to the root or to a folder 1 level from root.
Old Jan 22, 2008 | 06:28 PM
B L U E S L A T E's Avatar
Honda Accord
Did you select NTFS as your file system when you format the CF card? If you did so, you might want to reformat your CF card by selecting the FAT32 instead.
Old Jan 22, 2008 | 07:51 PM
adamr001's Avatar
It reads multiple folders deep no problem, but it's not going to read an MP4 file only an MP3 file.
junon
Jan 14, 2023 09:37 PM
ara777
Aug 15, 2018 04:11 AM
MThawkins86
Oct 24, 2015 02:07 AM
1Typhoon
Sep 25, 2015 08:45 PM
Ednica87
Sep 5, 2015 02:59 AM
