m35/45 rim question
Old Mar 10, 2008 | 08:55 AM
edpark30's Avatar
m35/45 rim question
If i were to get the m35/45 rims and installed them, do you guys recommend putting in spacers? which spacers are the best? what about the TPS? can i transfer from the stock rims to the new wheels?
do i need to be aware of anything else? or do i need to do anything else, when swapping?
Old Mar 10, 2008 | 01:25 PM
AlterZgo's Avatar
If you buy 2007+ M35/45 rims with TPMS in them, they should be compatible with your 07+ G35 and you would just need the dealer to reprogram them.
Otherwise, you will need to either buy new TPMS sensors and install them in the rims or take the ones out of your stock rims and install them on the M35/45 rims.
As for spacers, the M rims fit with no clearance issues without spacers. However, they will not look aggressive - especially with a drop.
If you don't plan on lowering your car, I would recommend at least 10 mm spacers all around. If you are going to lower your car, I'd recommend 20 mm spacers to push the rims out a little more.
The M35/45 rims uses Nissan's standard acorn style lug nut which is different than the lug nuts on the G35's OEM 18s. However, you can use the stock G's lug nuts. Carfreak used the stock G's lug nuts with no issues and I've done the same for about 4K miles now with no issues at all.
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
Kng0fHrts
Sep 15, 2015 05:40 PM
hurleyguys
18 Inch
Sep 9, 2015 12:24 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
EasySausage
Jul 14, 2015 11:17 PM
