Biggest lip (3"-4")
Old Apr 19, 2008 | 09:54 PM
NewYorkG35x's Avatar
Biggest lip (3"-4")
im about to get in a 08 g35s or g35xs this week what i want to know is what 20" chrome rims have rear lips 3-4 inches. ive been looking for about a week and only found 1 or 2. please help me out.
-andy
Old Apr 20, 2008 | 02:46 PM
g35_6gear's Avatar
If you are looking for a big custom lip, take a look at I-forged.
Old Apr 20, 2008 | 02:56 PM
EnviedG35's Avatar
Dont you need same size width wheels front/back for an X?
Old Apr 20, 2008 | 03:54 PM
i am not sure about the 07-08 but i no you can run staggered in first gen but u have to pull the awd fuse. i am not sure for the 2nd gen
Old Apr 20, 2008 | 03:56 PM
EnviedG35's Avatar
Why buy an X if you're just going to pull the fuse and disable the awd. Seems like a waste of money to me. From what ive seen, the 2nd gens arent that simple to disable the awd system. But then again, why spend the extra on an X if when you shoulda just got a regular rwd model.
Old Apr 20, 2008 | 04:01 PM
i agree but i have not found an answer if its the same as the 1st gen. but i am trying to read up on it. if i cant run a stagered i will not get an x, i have an x now. well see if you have an info on the x's let me know.
Old Apr 20, 2008 | 07:10 PM
rpm&my_G35's Avatar
I can't help you re: rims, I know nothing about that stuff. sorry
You can't disable the 07/08 awd with a fuse. search, there are threads on it from last year.
Old Apr 20, 2008 | 07:46 PM
AlterZgo's Avatar
No need to disable the AWD. Just run the same diameters at all 4 corners and you can go with staggered widths with no problems.
Old Apr 20, 2008 | 10:05 PM
brownfv's Avatar
with iforged wheels you can get the same width on the rims but a "staggered" lip, for example 2" front and 3" rear lip.
Old Apr 20, 2008 | 10:18 PM
iforged wheels are expensive tho aren't they? im not looking to spend 4,500k on rims.
Old Apr 20, 2008 | 11:34 PM
EWG35's Avatar
I don't know much about mechanics of an "X" but I would think the offset not just the tire width might throw a wrench in your plans. As someone said before, you can have a staggered look with I Forged and run 8.5's Front and Back for instance with different lip sizes. Make sure your wheels are center front and back with identical offsets. I'd imagine if the back wheels gave you a wider stance, that may cause a gearing problem when turning. As I said I'm no expect, but check into that...
Old Apr 21, 2008 | 12:51 AM
brownfv's Avatar
just FYI a member on the FX boards has an AWD FX45, and runs staggered nismo wheels (LMGT4's) with no problems at all. the AWD systems on the cars are the same so maybe you wont have a problem.
Old May 2, 2008 | 06:52 PM
NyG35_08's Avatar
i have a g35x 07 with staggered wheels....D'Vinci 20" ...no problems at all
Old May 2, 2008 | 07:13 PM
ugaexploder's Avatar
tsw's have some deep lips
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
Picture Share
Feb 4, 2018 12:41 PM
dseet
Oct 11, 2015 12:40 AM
9tray turbo
Sep 29, 2015 10:22 PM
