Who has switched to synthetic oil?
Old Aug 2, 2008 | 11:49 AM
  #31
Linner's Avatar
i switched to AMSoil at 4000 miles.
Old Aug 2, 2008 | 11:51 AM
  #32
Linner's Avatar
Originally Posted by AlexF
I made the switch to Mobil 1 synthetic at my first dealer service at 5,000 miles. Brought my own oil but was told that I couldn't do it in the future and have to purchase the oil from them at $14 a quart
This is Ramsey Infiniti in NJ, doubt I'm going back there...here's me venting about the whole thing...
https://g35driver.com/forums/northeast/219875-ramsey-infiniti-nj-policies-piss-off-customers.html
wow that is the one i would go to and is where i bought my car, but i do all maintence myself so whew! another reason its called the stealership
14$ a quart is ridiculous. I think i pay 6$ for AMSoil shipped probably even cheaper bc I buy 4 gallons at a time.
Old Aug 2, 2008 | 08:50 PM
  #33
sredish's Avatar
running Royal Purple 5w40. put it in at 2800 and have been running it since.
Old Aug 2, 2008 | 09:00 PM
  #34
JGKG35's Avatar
Bring your own
I switched to Synthetic on the first oil change. I suggest bringing your own oil, the dealer price is high and they may not have a good selection. If you have mods you may want to consider using a 0W 40W oil. Mobil 1 now makes a 0W 30W. I have used Royal Purple and it increase the mileage
Old Aug 3, 2008 | 04:16 PM
  #35
airhoppz's Avatar
Any oil I can run to increase mileage between changes? I just put some Mobil 1 full synthetic in the other day and set my reminder for 4000 miles. I would like to get on the BMW-style maintenance curve (15000 miles between oil changes!?)
Thanks!
Old Aug 3, 2008 | 05:17 PM
  #36
JGKG35's Avatar
I would not suggest pushing it to 15K. I change at 7500, that's about twice a year. This is well within warranty limits and better for the engine. Keep in mind synthetic oil may keep its' lubricating properties longer, but it still gets dirty and dirt is what breaks down the oil and does the damage.
Old Aug 5, 2008 | 04:42 PM
  #37
klossfam's Avatar
I switched to full syn at the first change (3,750 mi). Full syn is a minor expense when you DIY on the oil changes. Second change at 7,500 mi and then sticking with the every 7,500 mile per Infiniti standards (Premium level is simply unnecessary). A lot of the big name syn oils are made by the same oil company monsters (i.e. Conoco)...I'd agree that Amsoil, ELF, Motul, Royal Purple are probably slightly better products but following the maintenance schedule, any name brand full syn is probably fine (I use Castrol or Pennzoil 5W30 full syn usually). For the budget minded here in Western NY, a local retailer (VALU Home Ctr) is always running Kendall GT-1 Full Syn (another Conoco product) at $2.99/qt for 5W30 or 10W30. That's a good deal!
Old Aug 21, 2008 | 02:44 PM
  #38
SkyGliner's Avatar
Arrow
Questions for all the oil experts here,
I bought my car second hand and it currently @ 60,000 miles. Let's assume the previous owner didn't use synoil at all. What should I do, if anything, to "clean up" my engine before putting synoil in?
I am a mechanically handicap so I don't think I can take out the engine and scrub it...
Old Aug 21, 2008 | 02:54 PM
  #39
gary c's Avatar
Synthetic Oil....when to change?
Since this is your second oil change it should be allright to switch to synthetic
now. Pep Boys had a deal on Mobil 1 with filter for $24.99 this last week, that's good oil and the price is right. You can change it yourself or find a
shop that will do it for you for around $10. I never go to the dealership unless I need warranty work done, that way I don't feel like I being screwed!
Gary
Old Aug 21, 2008 | 02:59 PM
  #40
gary c's Avatar
Do a oil change using good synthetic oil like Mobil 1 or Royal Purple along with
a quality filter like Mobil 1. Then change it again after 2K miles and your
engine should be cleaner. Keep an eye on the color of the oil every couple
weeks to see how clean it stays....good luck!
Gary
Old Aug 21, 2008 | 09:16 PM
  #41
Triton3.5's Avatar
I switched at 5000 miles,,, and run euro spec mobil-1 0w40
Old Aug 21, 2008 | 09:25 PM
  #42
sredish's Avatar
I think I put in 5w40 but was thinking of switching to an 0w40 next time.... not sure tho. your running an 0w40 in MN, surely then, I'd be safe in North Tx with it.
Old Aug 21, 2008 | 09:30 PM
  #43
C6Zhombre's Avatar
I made my first oil change at 999 with mobil 1 5/30 and mobil oil fitler. changed it again at 5500. I've got about 7500 now and it has never used any oil, and I beat the hell out of the car.
as far as cost, I do my own with rhyno ramps, just drive right up. You can get the walmart 5 gallon mobil 1 jugs for $25ish. Mobil Filter will run $11-12. Make sure you get the factory style brass crush washer for the drain plug, $.85. Not a problem, even for the not so mechanically inclined
Old Aug 22, 2008 | 08:52 AM
  #44
JayJay's Avatar
I know a guy who has a turbo nismo 350z and he told me he uses a 5w- 30 Valvoline synthetic blend and has no problem. Anybody else ever use Valvoline oil or has any input on this oil? Also is it true that if you use synthetic all you can also use conventional all?
http://www.valvoline.com/pages/produ....asp?product=4
Old Aug 22, 2008 | 07:43 PM
  #45
Triton3.5's Avatar
Last winter it got down to -10 to -15 below 0 F. and today was a humid 85. I think that euro spec oil is just the ticket for this car and almost all climates... my car uses no oil, and i have taken it to the drag strip on occasion, and autocrossed it, and also high speed runs to see if it will ever go faster than 130 so i run it hard at times,, the car, ( and motor) have always been more than willing,, actually this is the best AWD drivetrain i have ever had!!!! imo......
nissandrifter32
Dec 22, 2015 04:28 PM
celwin
V36 Engine, Exhaust, Drivetrain & FI
11
Sep 28, 2015 03:52 AM
DRG35R
Sep 16, 2015 05:33 AM
G35-2004-mt6
Sep 11, 2015 04:16 PM
