Homelink Mirror
Old Jun 3, 2008 | 12:41 PM
Borna's Avatar
Homelink Mirror
Hi,
I have an 07 sedan with the auto dimming mirror with no compass or homelink and would like to know if it is possible to retrofit an 08 auto dimming mirror with homelink only without having to do any modifications such as wiring.
In Dubai we are not given the option of getting our mirrors with homelink which is a slight disappointment.
I really do not like the look of the mirror with compass and also do not want to go for an aftermarket alternative rather than just getting the 08 mirror for NAV which is exactly like my current mirror only with the homelink button.
Can I just order the mirror from a dealer in the US and take it to my dealer and have them replace my current mirror?
My apologies for the long write-up but any help would be greatly appreciated.
Borna
Old Jun 4, 2008 | 08:03 AM
snowcrossmxz's Avatar
i think that might work, call a dealer and ask, it all depends on if the homelink system is inside in the mirror or if it is some where else in the car and just the buttons are on the mirror.
good luck
Old Jun 4, 2008 | 10:09 AM
Borna's Avatar
Thats what I'm confused about myself... I can't seem to find if it's in the mirror or not and the dealer here has no idea since they don't supply them. Hopefully one of the guys from Riverside can chime in.
Old Jun 4, 2008 | 11:21 AM
how many wires go from the mirror off into the car? i looked at it once but i forget what was there. i am going to assume that its in the mirror. i have the home link mirror and i will check it out today, and let ya know, we can compare
Old Jun 4, 2008 | 11:27 AM
Borna's Avatar
not sure how many wires go into the mirror so i'm going to have to check it out when i head out later on today.
hopefully its in the mirror so i just order it and switch them up.
thanks a lot for your help bro
Old Jun 4, 2008 | 12:18 PM
Ripmaster's Avatar
The Homelink is self contained in the OEM mirror! There will be three wires coming from the mirror - two seperate power leads and a ground. One of the power leads is for continous power, the other is for the compass once the ignition is on.
Old Jun 4, 2008 | 12:23 PM
Borna's Avatar
so that means the mirror is retrofittable without any modifications?
since i want the 08 nav mirror which doesnt have the compass (my car should have only 2 wires) it should just be a quick swap...
if so then that's great news and would like to order one if anyone knows where to do so, my dealer says they cant order one since infiniti of middle east doesnt supply them with the homelink mirror
thanks for ur help
Old Jun 4, 2008 | 02:47 PM
mIKE's Avatar
Yes, I believe it's an easy swap; the wiring for power is already there since you have an autodimming mirror. Let me double check the plug before I say its 100%
Just be careful about how you glue the new mirror on, and make sure you get the spot really really clean before you do it
Old Jun 4, 2008 | 07:48 PM
Borna's Avatar
wouldn't I just be able to change the mirror itself and leave the base? I don't really want to have to remove the base and have to re-glue a new one back on. thanks for your help Mike
Old Jun 5, 2008 | 09:18 AM
you can do it that way on the fords, so it may be possible, not sure.
sry, i forgot to look at my mirror this morning. im puten a reminder in my phone to check it at lunch
Old Jun 5, 2008 | 09:41 AM
Borna's Avatar
hopefully I'll be able to do that cause replacing the base would be too much of a hassle
thanks alot for your help snow
Old Jun 5, 2008 | 05:36 PM
Ripmaster's Avatar
YES - You will be able to simply remove your current mirror from the base already on the windshield, and replace it with the new one.
However, the wires do not "plug" into the mirror, rather they originate from inside the mirror and so you will have to either splice your new mirror wires to the existing wires, or remove the old wiring and re-run the new wires to back their power source!
One last tip: whichever option you choose, make sure your ground wire is properly grounded or the mirror will not work.
Old Jun 6, 2008 | 12:48 PM
Borna's Avatar
great thanks for the help and advice ripmaster...I'll probably just take it to the dealer and ask them to do it for me so I dont screw anything up
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
the93owner
Sep 28, 2015 10:37 PM
the93owner
Sep 27, 2015 05:23 PM
TNRocker
Sep 21, 2015 08:36 AM
G35-2004-mt6
Sep 11, 2015 04:16 PM
