Grounding Kits from Stillen
Old Jul 8, 2008 | 09:03 AM
  #31
G35Now!'s Avatar
Moderation-free
Originally Posted by donpisto
Just wondering how it's not a carrying current. If there is no current, there is no electricity. Current is needed for a signal to be carried, it all part of Ohm's law.
Also, check the last link under Conventional Current. It goes into more detail.
Hey, thanks for the links. I did check it, here's what it said:
a conductor that exists primarily to provide a low impedance path to the earth to prevent transient hazardous voltages from appearing on equipment; normally a grounding conductor does not carry current.
Also, IIRC the ground wires from a grounding kit are not carrying signals per se - otherwise your car wouldn't run before you install it. Grounding kits are designed to equalize voltage between grounding points, and potentially eliminate noise and spikes. People have varying opinions on effectiveness.
G/L
mtlruss
Lighting
Sep 9, 2015 07:44 PM
boostelevator
Engine - Power Adders
Sep 9, 2015 05:56 PM
JG_G35
Engine - Intake/Fuel
Sep 7, 2015 09:35 PM
