Window Roll Up Module Ploblems..Need Help!!
Old Aug 27, 2008 | 11:57 AM
earth0's Avatar
I Just installed mine KP-Window Roll up Module.and test it.
Ploblem: when press lock twice
- Window Roll-up only approx 4 inches and stop
So i have to repeat pressing lock couple time until it's all completely close.
Any advice would be appreciate.
Old Aug 27, 2008 | 12:23 PM
sredish's Avatar
how much of a pita was the install?
Old Aug 27, 2008 | 12:35 PM
earth0's Avatar
It's alittle.The most important is you need to becarefully taking off the panal.
Recommended to use mask tape.
Follow DIY KPTech instruction and you will be fine.This link also help.
http://www.kptechnologies.com/forums....php?f=2&t=393
I donno if any 08 G35 sedan ever install this yet.Right now i have disconnect the batterly to reset.Let see if it work. Anyone know how to solve mine ploblems? THX
Old Aug 27, 2008 | 09:18 PM
KPierson's Avatar
Where did you hook up the yellow wire? It sounds like you connected it wrong. If there is 12vdc on the yellow wire while the module is going up it will cause the module to stop.
Old Aug 27, 2008 | 10:41 PM
earth0's Avatar
Holy Sh*t You the BEST!!!!! It's work. I hook it wrong to the other blue.
the sky blue was hiding inside.After i fixed it's work really Great!!!
Thanks a bunch KP. I will get moonroof Module next.
Old Aug 27, 2008 | 10:51 PM
sredish's Avatar
Ok, total time for install and how hard are the wires to get to?
Old Aug 28, 2008 | 07:14 AM
KPierson's Avatar
Great to hear you got it fixed and it was something simple!
Old Aug 28, 2008 | 09:13 AM
earth0's Avatar
sredish,If you ask me now i would said 1hr.Very easy and simple as KP said.
They are two Blue wire ( 1 Blue and 1 Sky Blue thicker wire )
I just follow the instruction by color.Go for it.Very cool!!
Old Aug 28, 2008 | 09:23 AM
snowcrossmxz's Avatar
1/2 hour maybe, i did mine quick, wires are easy, except for the lock wire that goes to the key hole, smaller hands would help, i have huge paws and i got it done,
im interested in the moon roof too
Old Aug 28, 2008 | 02:31 PM
SFLG35's Avatar
FGC President
hey guys im currently running a groupbuy on all kptechnologies modules.
check them out here:
https://g35driver.com/forums/group-b...ml#post3377808
Dallsinghjr1
Sep 17, 2023 11:25 AM
DRG35R
Jan 31, 2016 07:14 AM
BradMD_96
Oct 6, 2015 09:31 AM
dcsbh1
Oct 1, 2015 03:15 PM
NyCrAzY
Oct 1, 2015 09:19 AM
