Bringing Oil to Dealership for Oil Change
Old Oct 28, 2008 | 07:57 PM
g35at's Avatar
Can someone explain more about this? How much do I have to buy? And if buying synthetic, should I buy Mobil 1? I have a 2008 G35x.
Thanks.
Old Oct 28, 2008 | 08:01 PM
mIKE's Avatar
any 5w30 is fine. You need 5 qts.
Old Oct 28, 2008 | 08:08 PM
geronimomoe's Avatar
Actually you'll need 6 quarts. The oil capacity is 5 1/8 quarts. Since you're under warranty, you should either stick with 5w-30 or 0w-30.
The better oils (per various websites) are:
1) Castrol Syntec 0w-30 (aka GC)
2) Amsoil SSO 0w-30
3) Pennzoil Platinum 5w-30
The oil that perform pretty very well but not in our viscosity range is:
1) Mobil1 0w-40
Mobil1 5w-30 hasn't performed that well in our engine.
Old Oct 28, 2008 | 08:09 PM
mIKE's Avatar
okay fine fine 6 qts...
Old Oct 28, 2008 | 08:26 PM
TaBzRx's Avatar
2) Amsoil SSO 0w-30
1) Mobil1 0w-40
Where did you get this information from? Just wondering because I used Mobil1 5w-30 for my first oil change about a month ago.
Old Oct 28, 2008 | 08:34 PM
Check out www.bobistheoilguy.com.
Old Oct 28, 2008 | 09:43 PM
2008G35XSinMD's Avatar
+1 on this website. Lots of good information. Will be doing a used oil analysis just for kicks at about 30K to see how my internals are doing.
Old Oct 28, 2008 | 09:59 PM
narek330's Avatar
if you bring the oil to the dealership for the oil change around how much should they be chargin to do it?
Old Oct 28, 2008 | 10:07 PM
mIKE's Avatar
Whatever the labor rate is for an oil change. Asking is the best way to find out.
Old Oct 28, 2008 | 11:01 PM
MMsG35's Avatar
2) Amsoil SSO 0w-30
1) Mobil1 0w-40
so I'm guessing Royal Purple is no good?
Old Oct 29, 2008 | 10:21 AM
Check out this forum and see examples of royal purple UOA's(Used oil analysis).
Old Oct 29, 2008 | 01:25 PM
It isn't the greatest for our engine.
Old Oct 29, 2008 | 04:01 PM
kool-aid's Avatar
i think my dealer charged me like $30 to do it on my x
JoeMac
Aug 20, 2015 10:17 AM
miata007
Aug 17, 2015 04:36 PM
Jiggerjuice
Aug 17, 2015 08:41 AM
ClwMike
Jul 23, 2015 12:55 PM
