NYC Wheather make me do this!!!!! Black out HD light!
Old Feb 11, 2009 | 03:05 AM
  #31
E-Ticket Ride's Avatar
Ideally, you would want to sand the inner shroud. A spray on plastic primer then a spray on high temp paint would work best. Many light coats are better than one thick coat. A clear coat to top it off and you're set.
A gloss or flat black is really personal preference, but a semi gloss/gloss would look nice on the inner shroud. Earth's looks flat black, but it's hard to tell from the pics.
Old Feb 11, 2009 | 03:33 AM
  #32
Defratos's Avatar
You're Despicable
Cool, but could you tell me what paint you used? because its hard finding these sort of things over here and so I might need to get it imported in.
Old Feb 11, 2009 | 03:36 AM
  #33
"Duplicolor" is a popular paint used by headlight modification guys. You can actually use any spray paint, but a high temp paint would be preferred since the projector does get hot inside the headlight housing.
Old Feb 11, 2009 | 06:13 AM
  #34
Defratos's Avatar
You're Despicable
Sweet thanks san~man
Old Feb 11, 2009 | 07:53 AM
  #35
earth0's Avatar
Ok I've understood everything but what type of paint did you use and what color was it? was it a spray on paint?
I used Duplicolor Primer Sandable and Duplicolor Mattblack
Sand the Chrome gentlely!
Primer Once and sand
MatteBlack Twice and I baked them with very low temp*for 1-2 minute.
Old Feb 11, 2009 | 10:39 AM
  #36
Defratos's Avatar
You're Despicable
sweet, thanks for the instructions earth0
djreinx
Engine - Electrical
Dec 10, 2015 01:48 AM
julian.dion
Jul 29, 2015 09:16 AM
laksjd84
Accessories
Jul 24, 2015 12:37 PM
ClwMike
Jul 23, 2015 12:55 PM
