vdc and slip light on?
Old Apr 22, 2009 | 05:30 PM
  #31
earth0's Avatar
2nd Update!! the light came up again!!!
ABS,VDC and Slip Light came on!!! I check Brake Fluid level and it's up to Max already.I guess i need to bring the g to the stealership.Any idea what's going on?
Old Apr 22, 2009 | 05:38 PM
  #32
GEE35FX's Avatar
Heck that's too bad, definitely take it in to the Stealership
Old Apr 22, 2009 | 05:52 PM
  #33
earth0's Avatar
Yeh! Just found this link from our G memeber.I think the different is that i got
3 light came on. VDC,ABS and Slip light.He mention about the Brake Lamp Fuse!
I will check it tonite and will update to you guy.
https://g35driver.com/forums/g-spot/...ights-all.html
Old Apr 22, 2009 | 06:34 PM
  #34
GEE35FX's Avatar
Thanks for keeping us updated, hope you get a fix soon.
Old Apr 22, 2009 | 08:14 PM
  #35
earth0's Avatar
Just check Brake Fuse and all other.Nothing wrong at all.Time to bring it to the stealership.I need to make an appointment with them atleast 7 days in order to get a loaner (only 2 loaner in Manhattan dealer... WTF!! )
Old Apr 23, 2009 | 03:27 AM
  #36
G35Tiko's Avatar
it has to do something with the brakes
Old Apr 23, 2009 | 09:17 AM
  #37
earth0's Avatar
Just made an appoitment with the dealer. Will have update to you guy soon.
BTW Mine Brake Pad is looking ok.Brake Fluid also ok.No fuse Damage.Will see!
Old May 1, 2009 | 12:00 AM
  #38
blackie83's Avatar
whats the result !!!
Old May 1, 2009 | 09:33 AM
  #39
earth0's Avatar
No result! since all the light go off like 2 days before the appointment date until now still no light.so i did not take the g to the stealership yet.
I hope no more light!! It's runnig great in past couple day.
Old May 1, 2009 | 09:36 AM
  #40
GEE35FX's Avatar
Fingers crossed for you earth, hoping this is it
Old May 1, 2009 | 09:53 AM
  #41
earth0's Avatar
Thanks!! Gee35x. I'm too finger cross.
Mann!! Mine wife and me drove pass the Subaru STI Dealership this morning.I'm consider to get 2010 model with 320HP if the G continue with ploblems!
Old May 7, 2009 | 01:10 AM
  #42
joex420's Avatar
I pulled the car decently hard, not all the way and the SLIP and VDC lights came on and stayed on, I remember seeing this thread a while ago so when i had a chance at a red light i turned the car on and off it went away, No lights for he rest of the day. I remember my friend and my dealership telling me that my rear pads are wearing out and I should change them by the end of summer. Don't know whats really going on but i'll wait on it for now.
Old May 7, 2009 | 09:40 AM
  #43
earth0's Avatar
Update! As of today May 7th still no light!
continue finger cross.Can anyone give me an idea when should i change the brake pad.I got it Brand New from March 2008 with normal driving with 8900mi
on it now.Thanks!!
Old May 7, 2009 | 10:19 AM
  #44
GEE35FX's Avatar
on it now.Thanks!!
Good stuff earth.
I would think your brake pads will be good for quite a while yet.
I purchased my 07 G35X in Dec 06 and have 40,000 kms (24,000 miles) on it now. The brakes are still fine even though I had to add less than 2 ounces of brake fluid to keep my VDC/Slip/Brake warning lights off.
I am fairly easy on my brakes. If my light comes on again I will definitely check the brake wear as that is an indicator that they are wearing.
I will be getting them checked again later this summer or if I notice my brakes behaving any differently.
Oh, I must add that I get them serviced once a year (disassembled, cleaned and caliper pins and slides lubed)
Old May 7, 2009 | 12:44 PM
  #45
earth0's Avatar
Thanks for you advised GEE35X. 24000mi is reasonable enough to be replace brakepad.Since i have read many posted The Stealer always mention to have BrakePad change if the light came on as warning.
