Two Issues
Old Apr 22, 2009 | 12:25 AM
jeffawong's Avatar
I had this prob in another car - what i did was get some lysol (whatever scent you prefer) and spray it into the fresh air intake for the a/c system. It worked great - no more funky odors. Going forward i shut off a/c early to dry out the evap core to prevent this from happening again.
good luck
Old Apr 22, 2009 | 08:14 AM
LiptonUCF's Avatar
Originally Posted by AesonVirus
Weird.. I have never had this happen.
Are you sure you haven't somehow gotten some dirt or grit into the washer fluid tank? Something has to be clogging it.
If I had to clear the jets once a month, I'd look for a better solution, like maybe pulling out the tank and giving it a good cleaning.
my jets began clogging soon after I bought the damn thing...never opened up the fill cap or anything(they always refill it at the dealership). The service manager says its a common problem.
Old Apr 22, 2009 | 10:58 AM
dohturdima's Avatar
May not be a bad idea to check the tank, but somehow I think that the place where I generally park overnight (prone to dusty winds, near the beach) has something to do with it. I'd rather clean the jets than use a cover (don't have access to a garage there).
G35Rican
Jul 31, 2024 01:37 AM
yosip1115
Sep 9, 2015 03:30 PM
socaldavid
Sep 5, 2015 04:35 AM
kevintandmd
Sep 3, 2015 06:41 PM
UT G35
Sep 3, 2015 03:58 PM
