Help with gas cap door and lock replacement and testing
Old Feb 12, 2018 | 05:55 PM
Samuel Kwok's Avatar
I bought this G35x preowned.
I just realized it's suppose to lock when I lock the car. The lock is broken.
I am opening it manually by pushing the right side of the fuel door but I want to see if it can be fixed and if it's a bigger problem than a broken lock.
What's my next step to troubleshoot this?
Attached Thumbnails Help with gas cap door and lock replacement and testing-img_5262.jpg   Help with gas cap door and lock replacement and testing-img_5261.jpg
Old Feb 12, 2018 | 06:04 PM
telcoman's Avatar
Veteran: Army
Close the flap
Shut off engine
Lock the doors
Flap should be locked
Telcoman
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
When you lock the vehicle from the fob it should lock the fuel door, to unlock the fuel door you have to double tap the unlock button on the fob to unlock the entire vehicle.
Not entirely sure what the FSM says about the fuel door but I'd start there.
Old Feb 12, 2018 | 06:06 PM
Hey, thanks.
Right now the lock is broken. I can push the right side of the door to open the fuel door.
Old Feb 12, 2018 | 06:48 PM
Scorpi0's Avatar
Originally Posted by Samuel Kwok
Hey, thanks.
Are u saying the latch is broken?
Old Feb 12, 2018 | 06:50 PM
I think so, because my friend said it's suppose to open by remote.
I am opening it like this now,
Old Feb 12, 2018 | 06:55 PM
Scorpi0's Avatar
So when u lock the doors, u can still open it like that?
Yes
Old Feb 12, 2018 | 07:07 PM
Scorpi0's Avatar
Either your gas cap door tab needs an adjustment, or your lock isnt working.
Leave the gas door open and keep locking and unlocking the doors. Do u see the little pin on the left side popping in and out?
Old Feb 12, 2018 | 07:09 PM
Scorpi0's Avatar
This thing....
Old Feb 12, 2018 | 07:19 PM
This thing....
I definitely don't have that. It's broken off.
I see the mechanism working when I unlock/lock it. I see a white round plastic going in/out but it's still inside hole.
That's the part I need. What is it call?
Old Feb 12, 2018 | 07:31 PM
Scorpi0's Avatar
Its called a fuel door lock actuator. Theyre about 50 bucks on ebay.
But if the assembly is working but only the plunger is missing, u might be able to fix it if you are good with tools and a bit of creativity.
Check out this thread: https://g35driver.com/forums/general...or-repair.html
Old Feb 12, 2018 | 07:53 PM
That's it, thanks.
I will glue something to it.
Old Feb 12, 2018 | 08:12 PM
Urbanengineer's Avatar
I literally drilled a hole into the plastic male portion that broke off and screwed a screw into it. It works well now as a lock!
Old Feb 13, 2018 | 05:41 PM
Scorpi0's Avatar
Haha. Thatll work. Wrap it with some tape to make it thicker and put some shrink tubing over it if u wanna make it look less ghetto. Careful tho....dont use a lighter to heat the shrink tubing either lol.
OP...any progress?
