fog light recommendation
Any 07 G35 sedan owner replace the fog light with PIAA Xtreme White 9006?
Is it pretty white and match stock HID?
If you replace it with other type of bulb, I love to know how much you like it too. Any pic at night would be great!
i don't know if this helps, but i have an 06 coupe, and i have replaced the stock fogs with many different kinds of bulbs. i ended up using sylvania silverstars and i would have to say they are the closest in color to the stock hid headlights. they are not yellow, blue, or purple, but very very white. imo, the look the best, and i even noticed a brighter light pattern on the road with them.
I installed HID fogs the other day and they're much, much better than the stock halogen bulbs, of course.
-- yeah yeah, this thread is worthless without pictures, I know...
--http://photos.viguera.net/images/A_0...0019_2ced4.jpg
Best I could do at night... the camera was getting the CRAP blinded out of it by the fogs...
http://photos.viguera.net/images/A_0...0023_674d4.jpg
I have 10k 9006 HID fogs and the stock 4300 d2s bulbs on the headlights. I'm not sure if I wanna go all 4300 or all 10k yet, because the stock looks nice and bright but 10k looks whiter.
Originally Posted by Altersys
it's beneficial to have a yellower fog. better with preventing too much dispersion in fog... the bluer the light, the more dispersion/refraction. that's why a lot of halogen fogs (PIAA, etc) are almost yellow.
With that said, I've never - not once - actually driven into a fog bank, or fog so thick that visibility was less than 1/2 or 3/4 mile. I figured I haven't and if I do I got bigger problems, so off with the halogens. :-)
Originally Posted by 07ivory6MT
hows the cutoff on those HID fogs with the Xenon in the halgon enclosure? and why not get the 3000k for fog thats what i plan on doin.. little bit more blue on the headlights and yellow on the fogs
hence, changing from one type of bulb to another can lead to less than ideal results. doesnt mean it will, but it can and often does.
Well i mean the HID conversion kits work fine and will produce crazy amounts of bright light.. the way they generally work on factory equipped vehicles is with projectors that are shielded for a cut off point.. if you drive you G or any other HID factory equipped vehicle to a flat (light colored preferably) wall (ie garage, house etc) theres a distinct cut off point to reduce glare into opposing drivers eyes..
now with halogens, that isn't the case.. they're not particularly directed but being less luminous they're not as offensive even though they cause quite a bit of glare as opposed to properly angled HID Xenon lights.
I was just curious as to what kind of cutoff the fogs were causing, would be nice if you could have just the fogs on and no headlights on the G.. but being a different color, I'm sure he could see the difference. I'm all for the HID Foglight mod, as long as its not used to blind other drivers. Still very VERY disappointed the G doesn't have REAL fogs like any other car, they should be lower on the bumper
I was planning on higher kelvin D2s bulbs for my Headlights and Yellow halogens or 3k HID for my fogs... a nice Blue/Yellow JDM mix
-- but visibility is improved significantly.I'll see if I can get some good night shots of fogs on/off. The last time I tried they just didn't come out well. The camera tries to compensate for it being dark out and you can't really see all that well.
Also keep in mind.. HID d2r d2s etc increase in kelvin temp over time.. So let those 10k warm in a bit before you decide how white they are
I guess I should wait and see.
I won't go with HID due to cost. Plus if I change to HID I want the projector as well which is more costly and difficult to do.
I rarely encounter foggy condition in my area. For me it's cosmetics reason rather than performance. I go with anything white to match with low/high beam HID.
Anybody tries the led in the fog housing? I see this when I check out PIAA bulbs
http://www.automotivelightingusa.com...oducts_id=1403
And I feel you on the projector... I definitely would have liked to go that route too, but that'd be a lot more work. Custom fabricating the housing to fit a projector in there, and there's not a whole lot of room compared to the main bulb...
But I figure if in the future somebody does it, I already have all the HID stuff and it's just a matter of doing the projector work without getting the ballasts, bulbs, etc.
