V36 Interior, Exterior & Lighting Interior & Exterior - Tech, Modifications, Lighting, Gauges and More
We need a writeup on this: V Foglights
Old May 18, 2008 | 07:01 PM
krazzyguju's Avatar
Can someone do a writeup on hotwiring the foglights so they stay on whenever you turn the parking lights on? I dont think it'd be real hard but I have no clue which wire goes to what but im sure there are some people here that know. This question gets asked alot on this board and it'd be nice to have a writeup on this. Someone PLEASE DO THIS.
Old May 18, 2008 | 09:39 PM
earth0's Avatar
I agreed
Yeh,I agreed with you.Can any one DIY How to wiring the city light with fogs
to have turn on togetther without turning the Headlight.
Old Jan 22, 2009 | 11:57 AM
TallyG's Avatar
Red face
Its been almost 8 months guys. doesnt anyone know a little bit about hotwiring. I would really appreciate any sort of help. Thanks guys.
Old Jan 22, 2009 | 12:50 PM
kregg's Avatar
This is the closest I have seen:
https://g35driver.com/forums/tech-07...us-models.html
These are daytime running lights, i know not the same but perhaps the relay provider has something for your request.
Gluck
Old Jan 22, 2009 | 03:58 PM
jsmonet's Avatar
it really should be as simple as splicing from the wire that trips the parking light relay to the one that trips the allow-the-fogs-to-turn-on relay. pardon the lack of technical jargon
anyone have a wiring schematic for that bit?
Old Jan 22, 2009 | 08:00 PM
kregg's Avatar
download the service manual. It has it.
Old Feb 20, 2009 | 09:39 AM
klossfam's Avatar
krazzyguju - This maybe a little late but I'm in the loop above - did the DRL on conversion noted above
Daytime Running Light aka DRL Set Up (US Models)
...I'd go the safe route and order a Fog Light module from KP Technologies. This will allow independent control of the fogs (my mod does that but the end result is a Canadian G35 with true DRLs)
Link to the product at KP Tech: http://www.kptechnologies.com/products.php#/12
NOTE: Kevin at KP does not yet list it for the 2007 G35 Sedan but he does for the 2008 Sedan...I'd check with him but my experience with my friend's 2007 G35x tells me it'll work on both if it works on one...
Old Feb 20, 2009 | 09:21 PM
EnviedG35's Avatar
All you would have to do is make a harness with a 4 pin relay. Using the switched on power (for the relay) and connect it to the wiring for the parking lights, and hook the relay up to your battery (12v source) and a ground. This way when you're parking lights are on, your fogs will be turned on via the switched on power from the parking lights, and stay on even when the headlights are switched on.
For exmaple,
pin 1-switched on power from parking lights
pin 2- 9006 plug going to fog lights
pin 3- 12v to battery
pin 4-chassis ground
twentyeggs
Sep 11, 2015 03:58 PM
gatorglaze
Intake & Exhaust
Aug 17, 2015 02:16 PM
as25656800
Aug 9, 2015 07:25 AM
luxman
Feb 26, 2003 02:45 AM
luxman
Feb 23, 2003 07:16 PM
