HID fog... anyone with expierence? Help
#48
sorry for the late reply JP1080INC....i forgot to subscribe to the thread.
i have a balast issue with mine. they dont like to catch the bulb after ignition(they cut off after being initially turned on).....got them from v-leds.com and do not recommend them.
but the ones my buddy picked up for his is350 work PERFECTLY. he got those from advanced automotive concepts.
#49
nice to hear the AAC ones are working well for him, that's where mine are coming from. how do you like your 6k's versus the stock ones? i'm contemplating doing them but not sure. if i am, might as well do it while i'm in there.
and do you have to keep throwing your car around to show us all up..... lol
#50
what was the color temp that you got for yours?
does AAC offer the 3000k HID KIT?
#51
#52
thanks for the heads up. i will stay away from v-leds.
i am either going with the AAC or the Mccullough.
#53
yes, the 3k hid is what I got on order from AAC. They're kits are specific to the bulb and for the 9006 location, they offer 3k to 10k.
And just saying that, the fog is mostly worthless for most applications. I wonder if it would be beneficial to use in a 6k fashion to use in conjunction with the headlights for more of a driving light setup.
#54
I was thinking the same thing. I dont know if it would be brighter but hummmm?
#55
#56
i might get a std. silverstar 9006 and put it in the fog location to see how the light is distributed. if it's high enough or whatever, then I may consider sending the 3ks back for some 6ks.... but I'll probably end up using the 3ks.
If I could just get the damn things to turn on and off independently of the headlights, then you could really see where they're working and take advantage of the amber lens. I'm investigating the KPTech deal right now.
Mr. Ivory, what 6k bulb are you using?
#58
i had the 6000k's in my fogs, wasn't a great idea, "white" lights does well at reflecting stuff, but it doesn't light up the road well. I took it out, b/c if it was making stop signs shine from further away, it's also potentially blinding on coming traffic... I put the stock bulbs back in, and i'll probably get 3000k to use, since it's yellow, it'll light up the road for more visibility when i need it, but not for everyday....
#59
Originally Posted by JP1080INC
SREDISH -- is this the 3000k kit you purchased?
#60
Yep, did it the other day when i was trying the luminics.
just remove the stock air box and take and look in behind the headlight housing and take the bulb out and thats about it. I only did the driver side though as a test. I hear the passenger side is a *****....
POST SOME PICS ASAP OF YOUR KIT - POR FAVOR
