What's wrong with tinting the windshield? My friend put on a layer of the new 70% clear film (uv and heat protection) and it rejects a ****load of heat with zero downside other than initial cost outlay
the front window is where most of the heat comes in the car
Well, I couldn't make it that day either and I have been kinda busy with stuffs... Also, I kinda changed the idea of having 25% tint on the front... hahaha
He blatantly said he didn't want it too dark and that it ended up way too dark. We should be giving the paint-shop sh*t for painting headlights that dark, he didn't ask for that dark
fail, at least if it would of been an overlay it could of been easily removed, painted headlights even if theyre not done that dark will look like *** when the headlights are shining thru, tail lights is different though
alright, thanks for all the compliments.
ended up sanding each headlight down with 800 grit and then 2000 grit, took about 4 hours each light and then clear coat, came out look like brand new, sorry again for the bad picture quality
