V36 Interior, Exterior & Lighting Interior & Exterior - Tech, Modifications, Lighting, Gauges and More
Can someone explain to me what 6000K lights are?
Old Apr 16, 2010 | 04:25 PM
soundmike's Avatar
D2S is what you're looking for.
The OEM is 4300k but eventually color shifts to 5000k, thus why if you've had the bulbs on for a long time and one needs replacement, it's better to replace both bulbs to ensure a match.
As far as light output is concerned, you want to take note of the Lumen's. It's inversely related to kelvin. That is, the higher the kelvin, the lower the lumen's, and vice versa.
Old Apr 16, 2010 | 04:53 PM
Swivel's Avatar
Moderator
Originally Posted by Defratos
Now where's the best place to order Philips 6000K Ultinon from?(
I have Ultinons and like them quite a bit, but I got them from a member here and not sure where he got them. I can ask.
soundmike, I'm no lighting expert but I still think lumens are a measure of light output and the colour temperature is the perceived quality of the light (warm, cool, daylight) and has no mathematical relation to lumens. I suspect what you mean is that typically, higher colour temp headlight bulbs emit fewer lumens than lower-temp bulbs.
Old Apr 16, 2010 | 05:17 PM
soundmike's Avatar
Yep, that's what i meant. I don't think they're mutually exclusive, but for automotive lighting, all else being equal*, it has proven to be pretty much on target.
*Say, comparing same bulb-type and wattage.
Old Apr 16, 2010 | 05:28 PM
Swivel's Avatar
Moderator
Actually the more I read about it the more conflicting info there seems to be, but generally we are in agreement.
Bottom line, I think the OP found the light he was looking for and it's a great choice for the application regardless of the science behind it.
Old Apr 16, 2010 | 05:32 PM
tbrillz35's Avatar
definately get philips ultinons if you are switching out your projector bulbs. I upgraded to 06+ projectors for my coupe and upgraded all my bulbs before I installed, Ultinon 6000k with luminics 2500k fogs. Got them all off eBay, and couldn't be any happier with the color and quality of these things. Anything over 6000k just doesn't look good IMO and just remind me of all the girls who want "pretty purple lights" or something.
You're looking for D2S's, but just look at the sylvania bumb replacement guide before buying any new bulbs to make sure you are getting the right type of bulb
Old Apr 17, 2010 | 03:31 AM
Defratos's Avatar
You're Despicable
Thanks for the feedback guys, I eventually order mine off Ijdm: http://store.ijdmtoy.com/JDM-Garax-D...2s_d2r_d2c.htm
I'm not too keen on buying bulbs off ebay, These are the same as Robby's so if they've been fine for over a year on his then hopefully they'll be just as ok on mine. Now as for the fogs, what does everyone suggest???
2500k for fogs? and if so what type? are they the same bulbs as the low beam lights?
Also are there any DIYs? because the one on the DIY section has broken links so the pics don't show up .
Old Apr 17, 2010 | 12:47 PM
tbrillz35's Avatar
2500 is a deep yellow, great for fogs. luminics have the best color IMO.
like i said before, just look at the sylvania bulb replacement guide (you can google it) and put in your year/make/model etc and it will give you all the lights and what type of bulb they take.
Old Apr 17, 2010 | 12:51 PM
tbrillz35's Avatar
There it is
http://www.sylvania.com/ConsumerProd...lacementGuide/
Old Apr 17, 2010 | 01:14 PM
Defratos's Avatar
You're Despicable
Cool thanks man, I'll check it out later
snic09
Nov 8, 2017 01:46 PM
eunosz
Aug 29, 2015 02:03 AM
jbmw002
Drivetrain
Aug 27, 2015 03:01 PM
