V36 Interior, Exterior & Lighting Interior & Exterior - Tech, Modifications, Lighting, Gauges and More
Weather Strip on door
Old Aug 22, 2010 | 02:47 PM
Rizzagt22's Avatar
The rubber weather trim around my door keeps popping out from the top portion above the window. What tool or method do you guys use to put it back into place? The rubber has wedges bult into it, but Im having trouble getting it back into the grooves around the door.
Old Sep 17, 2010 | 03:35 PM
PG35_LA's Avatar
I had the same problem, I just went to the body shop down the street from my house and had them put it back on. They just charged me $10 bucks to glue it back, the shop is out here in Canoga Park. I am sure any body shop can put it back on for cheaper than that. If not hit me up and I can give you the address of the shop here.
Old Sep 17, 2010 | 06:32 PM
Q8y_drifter's Avatar
No need to glue it on. Just take off the strip from the beginning at the tip of the window until you reach the area where the strip popped off. Then reinstall it by installing the strip into the lower groove first and then the upper, Keep doing this (lower then upper, lower then upper, etc) until you reach the tip of the window and just snap it back in place. It's kinda hard to explain sorry if it's not clear what I meant.
Old Sep 17, 2010 | 07:45 PM
Borna's Avatar
^ +1
That's about as clearly as one could explain it man, good job. lol
Old Sep 27, 2010 | 02:10 PM
texas rangers1's Avatar
Crazy! I just popped mine back in on my left passanger side.. I did notice that would only pop in half of the way on the top portion.
Old Oct 2, 2010 | 12:10 AM
prech's Avatar
The dealership could likely affix the weatherstripping too, there's a TSB out and I had mine worked on earlier last year
Old Oct 6, 2010 | 09:02 PM
theophilus's Avatar
i just used a flathead screwdriver to pop it back in place. worked perfectly.
Dallsinghjr1
Sep 17, 2023 11:25 AM
RA081024
Interior
Oct 27, 2015 07:27 PM
Learned Hand
Oct 1, 2015 09:02 AM
douglas555
Sep 10, 2015 04:48 PM
jbmw002
Sep 3, 2015 08:42 PM
