V36 Interior, Exterior & Lighting Interior & Exterior - Tech, Modifications, Lighting, Gauges and More
seat memory gone
Old Dec 1, 2010 | 02:50 PM
Roblinds's Avatar
seat memory gone
Im sure there is a thread, but i couldnt find it.
changed my battery, lost seat memeory and now it wont take a new setting either.
how to fix?
Thanks!
Old Dec 1, 2010 | 03:47 PM
AesonVirus's Avatar
Losing your seat memory is normal when the battery is removed but you should be able to enter a new setting.
You will also need to reset your Automatic Window/s as well. Roll the window down, holding the button in the entire time and another five seconds after it's all the way down. Then roll the window back up, holding the switch another five seconds after it's up. Do this for each of your auto windows.
As for the seats, you should be able to set a new setting. I can only suggest you make sure you're doing it correctly.
Old Dec 1, 2010 | 03:50 PM
Roblinds's Avatar
Thanks man,
Old Dec 1, 2010 | 09:35 PM
kool_yaar's Avatar
^ what aeson said, for seats have ur car in the ON on START position and adjust all ur seat, steering. mirrors etc to ur liking, then hold SET for a few seconds and the leds for the 1 & 2 memory buttons will light up, then let go of of SET and simply press and hold the number where ud like to save the settings and u should be all good.
Dallsinghjr1
Sep 17, 2023 11:25 AM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
doakley92
Sep 25, 2015 12:58 PM
zcherub
Sep 10, 2015 12:03 PM
pasjr1972
Sep 1, 2015 10:17 PM
