V36 Interior, Exterior & Lighting Interior & Exterior - Tech, Modifications, Lighting, Gauges and More
How to get autox rear diffuser to stay on?
Old Feb 22, 2011 | 11:23 AM
suby01's Avatar
I had the autox kit rear diffuser for a couple years now, and it comes with the 3M doulble sided tape to attach to the lower bumper. But in different places it was peeling back, so I got some industrial 3M tape and put that on, it held up a little better but now my cars in storage and i looked at it the other day it is is also starting to peel back.
any tips or other solutions for this problem that anyone on here has?
im thinking of maybe having it "bondoed" to the back bumper but then that means that the rear would need to be resprayed, and may be expensive.
any other ways to get around this?
Old Feb 22, 2011 | 01:02 PM
E-Ticket Ride's Avatar
Your only alternative is to glue it on.
Old Feb 22, 2011 | 02:28 PM
J2S2M's Avatar
Is this a common problem in all aftermarket rear diffusers?
Old Feb 23, 2011 | 09:32 PM
djfarhan's Avatar
^ it is on my roof spoiler
Old Feb 23, 2011 | 11:52 PM
kool_yaar's Avatar
mines been on for a long while and its not peeling at all, my guess is that you either installed it in cold weather, the surface was not clean enough, or you did not tape it up after install for a few hours to allow the 3m to bond properly.
Old Feb 24, 2011 | 07:49 AM
mishmosh's Avatar
Mine is on pretty good too. You might want to try cleaning the surfaces VERY well (including wax) and then applying 3M Adhesion Promoter the the surfaces before you stick on the 3M heavy duty double sided tap. Make sure you are using the clips to keep the bottom corner down.
Old Feb 24, 2011 | 09:17 AM
javisaman's Avatar
Had the same problem.
Fixed it by doing the following:
1. Cleaned the surface thoroughly (wash, isopropyl alcohol, wash, claybar)
2. Peel a little bit of the double sided tape (expose only half) and pull the covering tape over the diffuser to the outside.
3. Put the diffuser on. Move it around till it's perfect. Press the exposed tape to the bumper and pull the rest of the covering tape. Press the rest of the double sided tape down unto the bumper.
4. Then I used a hair dryer to slowly heat up along where the tape is. Press down HARD as you heat it up. I spent about 20min on this part.
5. Finally put all of the plastic tabs and screws on.
Old Feb 26, 2011 | 10:50 PM
KuroV36's Avatar
is it hard to remove the diffuser w/o damaging it? Id like to redo my install since its a bit off
Old Feb 26, 2011 | 10:53 PM
kennymo's Avatar
heat it up first
Old Feb 28, 2011 | 11:54 PM
KuroV36's Avatar
can I still use the original adhesive or do I need to replace it? its been on my car since may.
Old Jul 18, 2011 | 03:22 PM
2GoRNot2G's Avatar
Make sure that the surface is clean and dry with no residue (I use Cleansolve) and also make sure to use the 3M adhesive activator before installing. The 3M activator is available in small packages with foam application pad... you will only need one or two of these for the rear difusser. I've installed all of my body work (front lip, roof spoiler, AutoKits X rear spoiler, and AutoKitsX rear diffuser) with the method and have never had any of the parts lift or peal.
Old Jul 18, 2011 | 03:25 PM
2GoRNot2G's Avatar
You'll definitely want to remove all of the old 3M tape and replace it with new 3M tape once you remove the diffusser. Make sure you use 3M automotive tape. If you use another brand or any other 3M (other than automotive grade tape) the UV light will get to it and it will eventually start to lose its adhesion.
Old Jul 18, 2011 | 03:40 PM
kool_yaar's Avatar
^ way to bring a dead thread back to life lol... but the 3M adhesive activator is a good add for sure, i used it on my interior kit on my last car since the kit kept coming off and with that little brush tube it kept the kit on till the very end.
Old Jul 18, 2011 | 07:42 PM
2GoRNot2G's Avatar
LOL. Didn't even realize that this thread was that old until you mentioned it... Oh well... guess it will be good info for the next guy.
Old Aug 17, 2012 | 09:30 AM
suby01's Avatar
hey guys a year later.
im still having a super big issue with it staying on.
i used a clean surface.. 3m and got it to hold for about 6 months.
lastly i used adhesive cement. it stayed on for a couple days.
i mean it stays on strong doesnt fly off or anything but the edges peel and seperate and you can tell its been glued or taped. :/
i am out of ideas. any new suggestions???
thanks!
