V36 Interior, Exterior & Lighting Interior & Exterior - Tech, Modifications, Lighting, Gauges and More
Added fog lights to my bumper
Old Jun 13, 2011 | 07:14 PM
samsizzle's Avatar
Originally Posted by zoop425
The wiring is easy! You wire it just like if you were adding hids to the stock fog housing. I used a direct harness so it takes power from the battery and just takes the signal from the stock harness.
where do you get a harness from? i'm using my old HID ballasts from my accord, so i just have stripped bare wires
Old Jun 13, 2011 | 08:14 PM
zoop425's Avatar
The battery harness I got from ddm tuning
Old Jun 13, 2011 | 09:20 PM
GXXXV X's Avatar
Lol I'm definitely doing this! A little nervous bout the wiring but mainly I'm not good at hiding the wires...any tips?
Old Jun 13, 2011 | 11:54 PM
samsizzle's Avatar
do we need a relay or fuse when connecting to the battery as an extra precaution?
Old Jun 14, 2011 | 12:31 AM
vqsmile's Avatar
a l w a y s !!!
Old Jun 14, 2011 | 02:25 AM
zoop425's Avatar
Originally Posted by vqsmile
a l w a y s !!!
Yes thats correct.. you can get premade harnesses which makes it 1000x easier with connections and relays and fuses in line
Old Jun 14, 2011 | 03:30 AM
samsizzle's Avatar
thanks for the info guys, so before I order can you please see if i'm getting the right stuff. I'm pretty confused as im sure others doing this mod might be
I just want the fog housing, proper lenses, and relay:
ddm tuning relay harness: http://www.ddmtuning.com/Products/HI...Wiring-Harness (do I need a specific adapter size to tap into our existing fogs?)
fog light housing, is it 3"?: http://www.theretrofitsource.com/pro...hrhmi53e644vuj (does this already come with lens???)
the 3" STI-R lenses, do I need them for the above housing??: http://www.theretrofitsource.com/pro...cts_id=85{6}39
Old Jun 14, 2011 | 09:24 AM
zoop425's Avatar
Let me fix that for you. Get the harness from rfs. The housings are projectors and come with clear lenses already no additional ones needed. You will then need bulbs and ballasts
Old Jun 14, 2011 | 10:34 AM
Locksmith's Avatar
Pix in the daylight of everything installed? I see pix in the daylight without the front bumper on but I wanna see how it looks with everything put back together.
Old Jun 14, 2011 | 10:36 AM
infinitig35's Avatar
Damn, that looks good. A lot of work though!
Old Jun 14, 2011 | 06:53 PM
samsizzle's Avatar
thanks for the quick reply ordered the projectors and am going to pick up the relay harness from DDM tuning's san diego location since it's 10 minutes from my place.
cant wait to install these! to tap into the low beams, we need the 9006 adapter correct?
also pics with the front bumper installed when you get a chance please, want to see how I should position them before I cut them out, leaning towards having them parallel with the headlight projectors but we'll see when the parts arrive
Old Jun 14, 2011 | 07:27 PM
zoop425's Avatar
you cant have them parallel with the headlight projectors. The fluid tank sticks out to far behind it and there is nothing to mount it to. also its much more sloped there. and do you mean the fog light? yes 9006.
here are some pics.. bezel not on yet because Im not sure if I want it or not.
Uploaded with ImageShack.us
I also finished the wiring for my headlights in prep for paint. My parking light is now a blinker and my fog and blinker are blank.. parking light wiring waiting for halo.
Old Jun 15, 2011 | 03:02 AM
samsizzle's Avatar
wow that is unique, props cant wait to install mine
wish our bumpers were shaped for them though ehhh
might look cool if someone could fit them into the sport bumper holes
Old Jun 15, 2011 | 07:06 AM
GXXXV X's Avatar
Those are some tiny cute fogs lol but they look sick...I'm thinking about just keeping my oem fogs there and just adding these on..
Old Jun 15, 2011 | 07:22 AM
  #30
GXXXV X's Avatar
I'm confused. It says wanna bulb wit ur purchase? But the only one available for the blazer fogs kit is an 880 bulb
