V36 Interior, Exterior & Lighting Interior & Exterior - Tech, Modifications, Lighting, Gauges and More
Lights going out after 30 seconds
Old May 14, 2012 | 12:20 AM
alltechneeds's Avatar
My g35 2007 sport sedan driver side headlights goes out after 30 seconds of turning it on, what could be the issue, I never had the lights changes etc, I noticed the little small one orange light went out completely.
Also does anyone know when I can get a replacement fog light wire harness.
M~
Old May 14, 2012 | 03:59 AM
Swagger_Jacker's Avatar
Sounds like a bad HID bulb. To test it swap driver side with passenger side. If problem follows order new HID bulbs. I replace both when one goes bad. 2 reasons, 1 color may not match 2 spare bulb. If problem does not follow (i.e. drivers bulb is still turning off) its a bad ballast, (see infiniti or wreck yard). On to the park light. Replace with LED's).
What do you need fog harness for?
Old May 14, 2012 | 04:23 AM
B L U E S L A T E's Avatar
Honda Accord
Fog light harness is a part of main harness... so unless you want to change the main side harnesses, you don't wanna change that. It's hella expensive.. lol
What's wrong with it?
Old May 16, 2012 | 01:44 AM
Any update OP?
chinee
Jun 10, 2024 07:48 PM
Wayne9011
Aug 17, 2015 01:24 AM
Wayne9011
Jul 27, 2015 11:25 AM
newg37
Jul 26, 2015 09:32 AM
