V36 Interior, Exterior & Lighting Interior & Exterior - Tech, Modifications, Lighting, Gauges and More
Roof Spoiler Issues
Old Jun 1, 2012 | 09:38 AM
txg35x's Avatar
Roof Spoiler Issues
Ok, this is pissing me off. I've had to retape my roof spoiler 3 times so far in the last 4 months. Twice with 3M tape from Autozone and once with VHT. Each time it starts coming up in the corners then the tape seperates from the glass in spot and from the spoiler in others. I know I'm not doing anything wrong when I install it, so what can my problem be?
Old Jun 1, 2012 | 01:31 PM
irishsig's Avatar
Is there any residue on the window?
I usually let the car sit out in the sun for 20 min, the heat will help with adhesion.
Then clean the glass with a lint free rag & rubbing alcohol.
I used this stuff on my rear spoiler.
Amazon Amazon
Super strong. That spoiler ain't budging.
I got it at Home Depot.
Old Jun 1, 2012 | 01:43 PM
The Stimulation's Avatar
Perhaps it's the roof spoiler itself. Without any adhesive, how well does it form to the surface? If gaps are large, then maybe the curvature is too much to hold and thus the reason why it's coming off. As irishsig mentioned, cleaning is crucial. You must make sure that it's clean as possibly so you have maximum contact. Have some friends help you out and hold down the spoiler for a few minutes to ensure contact.
Old Jun 1, 2012 | 01:44 PM
HotRodG35's Avatar
I used 3M tape and has kept the roof spoiler on for 6 years.
Ensure the surface is cleaned thoroughly and temp should be above 70 F for better results.
Apply pressure for a few minutes when installing spoiler.
Old Jun 1, 2012 | 03:14 PM
bat6wc's Avatar
3 dabs of clear silicone adhesive on the ends and middle will lock that thing down. Its also really not bad to remove either when time comes.
Old Jun 1, 2012 | 03:21 PM
txg35x's Avatar
I do have some gaps on the ends but I wouldn't think they're big enough to keep doing this.
I'll try the silicone adhesive also. Thanks guys.
Old Jun 1, 2012 | 03:22 PM
GeeGirl82's Avatar
I used windshield sealant AND 3M on my CF VIS roof spoiler and haven't had any problems.
Old Jun 3, 2012 | 01:25 AM
djfarhan's Avatar
i used heavy duty 3m tape and no issues so far, knock on wood
Old Jun 3, 2012 | 01:55 AM
sdz33's Avatar
Try scuffing the adhesion points on the spoiler with 600 grit and clean it well with alcohol or degreaser and try to apply it on a warm day... Make sure whatever you use that you let it fully dry or evaporate before applying double sided tape... That should do the trick!
w4kj4k
Other Cars
Mar 6, 2016 08:06 PM
nickmcc123
Aug 27, 2015 02:29 PM
linedr89
Aug 17, 2015 05:11 PM
nickmcc123
Jul 29, 2015 05:14 PM
newg37
Jul 26, 2015 09:32 AM
