West Serving AZ, CA, HI, NV
fuel gauge
Old Apr 27, 2018 | 12:48 AM
vinnieboi's Avatar
fuel gauge
anyone here how to fix a fuel gauge, mine doesn't go all the way to E,
Old Apr 27, 2018 | 08:06 AM
Scorpi0's Avatar
Remove rear seat, remove fuel pump. Clean sending unit on pump and reinstall.
Old Apr 27, 2018 | 10:02 AM
vinnieboi's Avatar
would you post me a picture how to remove the seat pls.
Old Apr 27, 2018 | 11:12 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Unplug the harness on the fuel pump and read resistance across pins 2 and 5. Resistance changes from 3-80 ohms depending on how much fuel is in the tank, read the resistance with a full tank, then drive it till 50% and measure again, half tank should be about 40 ohms, then drive until your gas gauge stops, get that reading, drive more and see if the ohms reading continues to change.
If the ohms stays the same the problem is the value being sent from the pump, if the ohms DOES change as you continue to use fuel all the way down to pretty much empty then the problem is likely your combination meter which is very common on these vehicles.
Old Apr 27, 2018 | 02:26 PM
vinnieboi's Avatar
fuel gauge
where's fuel gauge located at.
Old Apr 27, 2018 | 02:27 PM
vinnieboi's Avatar
fuel gauge
where that fuel gauge harness located at the car.
Old Apr 27, 2018 | 07:15 PM
cleric670's Avatar
BANNED!!!
Under the back seat. Youtube it or something.
Old Apr 27, 2018 | 08:28 PM
vinnieboi's Avatar
fuel gauge
which side though.
Old Apr 28, 2018 | 04:34 AM
Scorpi0's Avatar
Originally Posted by vinnieboi
which side though.
The west side
Old Apr 28, 2018 | 10:51 AM
vinnieboi's Avatar
fuel gauge
lol!
Old Apr 30, 2018 | 08:06 PM
coffeysm's Avatar
If you have a coupe you'll have two access holes. I think the pump is on the passenger side and the other sending unit is on the driver.
Old Apr 30, 2018 | 09:53 PM
vinnieboi's Avatar
fuel gauge
yeah!i have coupe.
Seano350GT
Feb 24, 2020 12:10 PM
sabino787
Mar 7, 2014 09:43 PM
DEMoLITIoN
Northern California
61
Jul 28, 2012 08:45 PM
jutn35
Jul 9, 2010 04:29 PM
saborz
Dec 29, 2006 12:43 AM
