TOkico D Specs! with Free Rear Extension!
Old Feb 10, 2006 | 04:55 PM
CreativeAutoworks's Avatar
We got a few D specs DSP 7 and 9's that we'll put out on speical, or $525 shipped including the rear dampening extensions, we will combo them with Tein H techs' or S techs for $650 shipped.
Place your order now!
James@creativeautoworks.com
Old Feb 11, 2006 | 08:09 PM
willthethrill's Avatar
How much for just the extensions? Are they universal, meaning will they work with both the 7's and the 9's or are they specific to the shock model and the car model?
Old Feb 11, 2006 | 10:04 PM
TwoK4drSi's Avatar
if you have the h-techs for the z, which on should I get? also, what are the extensions? pics?
Old Feb 12, 2006 | 02:12 AM
Jee_35's Avatar
PM Sent, Thanks!
Old Feb 13, 2006 | 01:57 PM
Rear extensions are $30 shipped, they will work on both DSP 7 and 9!
Old Feb 13, 2006 | 01:59 PM
We would recommend the DSP 9 for the 350Z, the extensions are used for the rear dampening, it will allow you to change the dampening in the rear without having to remove the rear shock assembly. All that is needed is to open the trunk once installed and make your adjustments.
Old Feb 13, 2006 | 02:00 PM
TwoK4drSi's Avatar
Pics Pics Pics!
Old Feb 13, 2006 | 06:03 PM
Jee_35's Avatar
I just ordered the DSP 7's with the 350z H-Techs from James. Very smooth and quick transaction. Great deal also, Tokico's usually run you at least 620$ shipped, and the springs will go from 145-160$. Saving at least 100$. Ill post pics when I get them in and installed. I might/might not try the extensions, but I'll post pics of them also. Again, thanks James!
-Jim
Old Feb 25, 2006 | 07:09 PM
ksig113's Avatar
James
Do you still have these in stock and is the promo still available?
D Spec DSP 9, 350z H-Tech
Old Mar 13, 2006 | 09:53 PM
Endless G's Avatar
Do you still have the shock in stock and are the promo over !??
Old Mar 15, 2006 | 02:38 PM
robbdogg's Avatar
Got everything Monday James. Thanks!
Th611
Oct 27, 2015 03:48 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
Soumilg
Jul 18, 2015 12:33 PM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
