wheelspacer
Old May 23, 2006 | 09:15 AM
philogene's Avatar
mos high
wheelspacer
I finally put on my brakes and wheels in front dont fit.can I get a spacer for that or I am ****.Iforge said they could send two wheels with back space for 1400.Then I have two wheels thats not going to be used.Any body know what spacer to use.I need about 1.5 to 2inch space to clear the brake.
Old May 23, 2006 | 09:39 AM
JaxGman's Avatar
Wheel Spacers
I run a 5/8 or 5/16 i cant remeber which.. spacer from Pep Boys to clear my brembo's with my SSR's. They have various sizes at Pep Boys and run bout 15 bucks. I was able to use my stock wheel studs with the 5/8 spacer, barely... If using a spacer I would recommend longer wheel studs.
Now if you need 2 inches I would recommend u get the proper offset wheels, or u will be rubbin your fenders.
Old May 23, 2006 | 10:07 AM
superchargedg's Avatar
do a search for kic,s spacers they will have what you want.
Old May 23, 2006 | 10:40 AM
philogene's Avatar
mos high
Thanks.
Old Jun 20, 2006 | 01:15 PM
ichibausa's Avatar
Old Jun 20, 2006 | 01:51 PM
Mark350GT's Avatar
ooo nice brakes
Old Jun 20, 2006 | 02:15 PM
Blackbird V35's Avatar
why does everyone like kkics spacers so much? they are expensive and not hubcentric. H&R's are hubcentric and cheaper. I got a 15mm for my car for $96 at racerwheel.com
Old Jun 20, 2006 | 07:39 PM
ichibausa's Avatar
I had the same question too, some people paid $$$$ for the spacers but without the hub ring.
Old Jun 20, 2006 | 07:55 PM
Sundeviljay's Avatar
i got some cheap pep boys spacers as well to clear my rear wheels...bought the nismo long hub bolts and i have been good for almost 6 months
Old Jun 20, 2006 | 11:14 PM
kenchan's Avatar
i specifically run 15mm spacers from kics. they are the only ones that
have new studs on their 15mm spacers that i know of. i just bought
centering rings from them for like additional $25 for the pair. who cares,
it's cheap.
ichiba- i noted to you on another post that your spacers look good
except you don't have 15mm with new studs on them.
some of us don't want to use longer studs as we swap wheels
summer/winter and don't want to go though banging out the studs
each time.
Old Jun 21, 2006 | 02:32 AM
truplay8's Avatar
THE BATMOBILE
sick
Old Jun 26, 2006 | 07:11 AM
philogene's Avatar
mos high
I ordered spacers from ichibausa 5mm and 15mm.The spacers are good but they did not clear the brakes.The 5 to small the 15 to big so primier performance in pembroke pines FL custom made some for me 150 for the pair.They fit right in the hub perfect .So any body have the same prob as me check them out.
Old Oct 18, 2007 | 11:08 PM
O HELLA OEM's Avatar
red rims nice
KccBaby
Archived Sales
Jul 27, 2009 04:45 PM
KccBaby
Archived Sales
Jul 23, 2009 11:18 PM
KccBaby
Canada
Jul 21, 2009 04:33 PM
GreyGoose35
Feb 19, 2009 08:21 PM
