Spacers?
Old Jun 12, 2006 | 06:59 PM
Packer445's Avatar
Spacers?
Hey guys i need to find some good spacers for my new rims. I have a 03 coupe and the brembo brakes take up to much room so i need spacers. Anyone have any suggestions? Thanks
Old Jun 12, 2006 | 08:44 PM
Blackbird V35's Avatar
Everyone recommends Project Kics and I don't know why. they are more expensive than H&R spacers and they arent even hubcentric! I bought the H&R spacers from a site called www.racerwheel.com and they work great
Old Jun 13, 2006 | 12:33 PM
kenchan's Avatar
you can get centering rings for the Kics.
Old Jun 13, 2006 | 08:30 PM
Packer445's Avatar
spacers
I talked to the guy at infiniti and he said that spacers can harm the car and run the risk of the wheel falling off. I dont think that it will make a huge difference. So is it safe to put spacers on?
Packer445's Avatar
bump
Old Jun 16, 2006 | 06:23 PM
ichibausa's Avatar
It's not safe if you don't put longer studs. We are the wheel spacers available & studs are included.
https://g35driver.com/forums/wheels-tires-vendor/102883-introducing-ichiba-usa-aluminum-wheel-spacer-all-size-available-350z-g35.html
Old Jun 17, 2006 | 01:01 AM
mondo's Avatar
with the Kics you don't have to replace studs.... just bolt them on and then bolt the wheel to the studs that come on the spacer.
These are 15mm front and 20mm back (I think, check my profile/posts)
Old Jun 18, 2006 | 06:00 PM
echephron's Avatar
what size spacers do you have in those pics with the OEM 19's?
Old Jun 20, 2006 | 01:14 PM
ichibausa's Avatar
https://g35driver.com/forums/showthread.php?t=102883
We have all sizes hubcentric wheel spacers. They have the longer studs and hubcentric directly bolt-on to your car.
So you don't have to worry o-rings or studs.
Old Jun 20, 2006 | 02:14 PM
Jellysick's Avatar
Do spacers cause premature wear on other parts? i.e. bearings or anything else?
If not, it looks like a great way to improve stance... However I thought I remembered reading somewhere that it will wear out some parts of the car quicker.
Old Jun 20, 2006 | 03:59 PM
ichibausa's Avatar
Nope, All spacers are just plug and play.
Old Jun 20, 2006 | 11:24 PM
kenchan's Avatar
hummmmmmm... i don't completely agree.
wheel spacers will affect bearing and sus wear if the offset is set too aggressively.
for most people, "plug and play" usually means the user will not need
to remove the factory studs to replace with new longer studs.
Old Jun 26, 2006 | 01:46 AM
ichibausa's Avatar
http://www.my350z.com/forum/showthread.php?t=199634
Hope this link can help!
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
w4kj4k
Oct 2, 2015 07:57 PM
BradMD_96
Intake & Exhaust
Sep 28, 2015 06:25 PM
