Need help, need advice, anything..., desperately !
Old Sep 25, 2003 | 11:56 AM
gr4n23's Avatar
I ruined the thread on the wheel mount till its impossible to install the lug nuts, is it ok If I just put 4 nuts instead of 5 ?? Anyone had this kind of experience ??
Old Sep 25, 2003 | 12:11 PM
Sicshift's Avatar
Re: Need help, need advice, anything..., desperately !
yeah, it's fine to drive on it. I'd probably change it as fast as you can though. I drove with 4 instead of 5 on my Mustang for many years and never had 1 problem.
04 Sedan. Obs. Black W/ Willow. Premium, Navigation, Sport Tuned. 35% Tint, K @ N, Brand Spankin New.
Old Sep 25, 2003 | 03:32 PM
3point5SE_Auto's Avatar
Can you chase the threads or run a die over the threads to make new ones? This should be pretty easy if you have access to a tap and die set. a tap and die set should run 50.00 or so and then you can return it
Better Life thru Chemistry
Old Sep 25, 2003 | 04:03 PM
chinee's Avatar
I think you can drive with just four of the five bolts, but given the issue with rotor warpage on our G's....you don't want to find out that the uneven pressure of the rim against the rotors may actually cause more warpage.
Check with your mechanic/dealer to get this fixed as soon as possible.
<font color=red>chinee</font color=red>
2003.5 G35s
Old Sep 25, 2003 | 06:37 PM
Shader7's Avatar
Any mechanic, dealer, or even some tire-sales places can replace your wheel stud. Shouldn't be expensive; do it as soon as you can.
03.5 Coupe - Black/Willow, 6MT, Premium, Navi, Aero, Sat
Old Sep 26, 2003 | 01:48 PM
ryoken's Avatar
I would drive very carefully. Definately do not drive aggressively. Personally, I'd have it towed somewhere to have it fixed, you can use the towing service that comes with the purchase of the car.
The wheel studs can be replaced, and should be done ASAP.
Old Sep 26, 2003 | 05:19 PM
DiscountTireCo's Avatar
You will be fine until you can get it fixed at a dealer or repair shop. I would ot drive like you are at the races but if the other 4 are on and torqued down you shouldn't have anything to worry about.
Thank you,
Discount Tire Direct
(888)459-4080 mention G35driver
Dallsinghjr1
Sep 17, 2023 11:25 AM
Rose M
Oct 12, 2015 10:00 AM
6spdGspot
Oct 5, 2015 01:55 PM
dcsbh1
Oct 1, 2015 03:15 PM
Learned Hand
Oct 1, 2015 09:02 AM
