G35 SNOW TIRES...
Old Sep 29, 2003 | 02:24 PM
stevenebin's Avatar
G35 SNOW TIRES...
Could anyone please recommend high performance snow tires for the G35 Coupe with 17" wheels? I've been looking online but couldn't find any solid tires that fit the coupe's dimensions.
Let me know guys! The G35 rocks!
I'm looking for tires that perform well in rain, snow and ice (or as well as could be expected for a rear-wheel drive car). They don't need to perform excellently in dry weather, as I'll keep my current tires.
Thanks!
- Steve
Old Sep 29, 2003 | 06:24 PM
youngnreckless's Avatar
Re: G35 SNOW TIRES...
pirelli snowsport 210
225/50/17 front
225/55/17 rear
Old Sep 29, 2003 | 07:11 PM
Balzac72's Avatar
G SQUAD
Does anything exist for the 18" wheels? If so, do they work well??
03.5 6spd DG/G aero pk/kit
He who makes a beast of himself gets rid of the pain of being a man.
Old Sep 29, 2003 | 09:23 PM
uheenada's Avatar
i thought 18s don't get any snow tires.. i couldn't find any snow tires from any online tire sites...
Old Sep 29, 2003 | 09:45 PM
neohh's Avatar
I think Bridgestone Blizzak LM-22 has size 18
Old Sep 29, 2003 | 10:24 PM
Fiebru's Avatar
I had researched this some months ago and I looked in The Tire Rack. I think I was going to have to buy Bridgestone Blizzaks for the back and Michelin Alpin Pilots for the front. Neither company made both front and back sizes.
Old Sep 30, 2003 | 12:41 AM
Balzac72's Avatar
G SQUAD
Do you remember the prices for the fronts and rears? Were they the same width as stock or thinner? Thanks!
Old Sep 30, 2003 | 09:29 AM
telegramsam's Avatar
It's Showtime**
I am running 18" snowsports. See my ride pics for a shot.
Where's the Tylenol
Old Sep 30, 2003 | 09:57 AM
Lucky_Forward's Avatar
Hi, I have a 6MT with the Michelin Pilots, and I'm wondering how they'll handle winter driving if I'm able to avoid snow. I live in Baltimore, MD where we get a moderate amount of snow each winter, and I plan to drive my Dodge truck if there's snow or threat of snow, and leave my G at home.
I tend to drive moderately, and rarely push the car to is handling limits anyway. So will the Pilots otherwise perform well in cold wet winter weather if I avoid snow?
Old Sep 30, 2003 | 11:01 AM
skyline810's Avatar
what size of snow do you guys use for your G35 6MT? I found a set of 17" rim already, but don't know what size I should take? Any hints?
Old Sep 30, 2003 | 11:17 AM
Balzac72's Avatar
G SQUAD
For snow tires, the HIGHER the profile of the tire it is, the easier it is for the tire to do its job and shed snow and ice. Lo pro tires are the worst kind of tires for snow work, which is why I'm curious as to how people did last winter with snow tires.
Old Sep 30, 2003 | 11:27 AM
Msedanman's Avatar
O.F. Administrator
Hi bro, I've got 225/55/17 Yokohama Winter AVS snows on Enkei CDR-9's for our winter up here in Ontario, Canada.
They perform well, and are not noisy.
<font color=red>GSM</font color=red> <font color=black>Silverstone Coupe</font color=black>
Old Oct 2, 2003 | 07:49 PM
wjfm1's Avatar
I am in Baltimore (Bel Air) and would not try it after last winter.
Snow was worse than in NY.
2003.5 G35C BL/GR, NAV, PREM, AERO, TINT, SPORT, Splash, V1
Old Oct 3, 2003 | 01:55 PM
donpalombella's Avatar
I've got Bridgestone Blizzak LM-22's on ASA KA-3 rims.
Front tires: 225/50VR17, rims: 17x7.5 5-114 ET35
Rear tires: 235/50HR17, same rims.
Everything fits and works great. See the Tirerack.
Old Oct 3, 2003 | 06:30 PM
medoug's Avatar
Hey donpalombella,
The rear tire size you chose result in almost 1/2" smaller outer diameter of tires than the 18" factory tires. Your speedometer and gear ratio will be off a little. I'm not sure if this will cause a problem with your VDC and traction control since the system checks for a speed difference between front and rear wheels. You might want to consider 225/55R17's instead for the rears which is a nearly perfect match to the factory tires.
Also, if you would like to compare the performance of different winter tires, there is a comparison in the November 2003 issue of Consumer Reports. A summary of the results of the comparison can be read here:
http://www.canada.com/calgary/specia...er/021005.html
G35 Coupe 6MT / Brilliant Silver / Graphite / Prem.Pkg. / BSM
Doug.
