VDC acting up after installing 19's
Old Jul 27, 2006 | 08:05 PM
prog35's Avatar
I wonder if anyone has had this happen and has a remedy.
I just installed 19" aftermarket wheels on my car and when I go to drive it....the VDC slip light comes on and the engine cuts power as if I'm spinning or sliding.
Anybody know what the heck is going on ?
Thanks
Old Jul 27, 2006 | 08:15 PM
avs007's Avatar
Thanks
What tires do you have on the front/back? Most likely you didn't stagger correctly.
Old Jul 27, 2006 | 08:21 PM
prog35's Avatar
I've got 245/35/19 in front and 275/30/19 in back...I thought this was the correct set-up?
Old Jul 27, 2006 | 08:31 PM
avs007's Avatar
If you have 245/35-19 on the fronts, the rears should be 275/35-19 to maintain proper stagger. The sidewalls of your rear tires are a little too small, so the rear tires are spinning about 4.6% faster than they should be, so the ECU probably thinks you are spinning out.
Old Jul 27, 2006 | 08:38 PM
guidoguy's Avatar
Yeah that VDC is real sensitive. Two different tires on each back wheel can cause the VDC to activate.
truplay8's Avatar
THE BATMOBILE
two different brands of tires in the front and back could be the problem
Old Jul 27, 2006 | 08:57 PM
avs007's Avatar
IMHO, that would only cause the VDC to activate when you take corners, because the grip would be different between the front and back.
But if I read the post correctly, the VDC was activating while just driving normally, which would lead me to believe his stagger is off. (which in his case, is off by 4.6%)
Old Jul 28, 2006 | 12:05 AM
r0csfinest's Avatar
i got that same exact setup and that happened to me the first day i got them installed.... hasnt happened since and its been about 3 months
Old Jul 28, 2006 | 09:05 AM
prog35's Avatar
Well today was my second day with this set up and the VDC didn't come on at all....and it's even raining!
Maybe the computer has to "re-learn" or something? Anyways I'll keep my fingers crossed that it'll be ok now like yours.
Thanks for all the tips guys!
Old Aug 1, 2006 | 10:39 AM
prog35's Avatar
Just an update....It's been about a week now and the VDC is back to normal.
I guess the car had to "learn" the difference with the new wheels/tires ?
Old Aug 1, 2006 | 02:20 PM
francis's Avatar
same thing happened to me. As soon as I got in my car and took off, the VDC light came on and the engine cut-off just like you had described. I believe in the "re-learning" theory.
It's only happened once and that was way back in january - 7 months ago.
Mry
Mar 3, 2023 01:03 AM
madmax032
Drivetrain
Jan 18, 2016 10:41 AM
Wayne9011
Aug 17, 2015 01:24 AM
Wayne9011
Jul 27, 2015 11:25 AM
