Ok More Help Needed Here
Old Oct 5, 2006 | 01:23 PM
rwcblkcoupe's Avatar
Alright guys..here we go.
I have 245/30/20 on 8.5 " wheels in the front and 275/30/20 on 10" wide wheels in the rear. 03 non brembo coupe...I dont like the way the 275/30/20's dont fill out the rims so im changing to 285's. However I also dont like the profile of the 30 series in the front(too low). First question. Would it look ok to have a 35 series in the front with a 30 series in the rear? I would go with 35 series all around but im told they wont fit?? the offset on the rear wheels are 25mm. Any help would be great..
Old Oct 5, 2006 | 01:43 PM
az1anbeethoven's Avatar
yeah...it would look ok...you can and should do 245/35/20 in the front no prob...but i would stick to 275/30/20 in the rear to have more of the same diameter all around...
Old Oct 5, 2006 | 08:08 PM
The only problem that i have is that the tire does not fill out the rim. It is back set and looks incorrect. It creates a weird gap. Thanks for your input..I think i will stay with the 30 series and go to the 285 in the rear
Old Oct 5, 2006 | 08:43 PM
DHCrocks's Avatar
a 255/30/20 (26.03") in the front will be as close to stock (25.98") diameter as you can get. The 245/30/20 (26.76") will be too big.
stick with the 285/30/20 in the rear it's also closer to stock then the 275/30/20.
Old Oct 6, 2006 | 01:59 AM
Ok im a little confused your speaking of diameter right? what is the difference between the two ..245-or 255 the diameter isnt changing the width is. Am I wrong here? Did you mean the 245/35/20 will be too big? Thanks for the input on the rears.
Old Oct 6, 2006 | 02:08 AM
caskyline's Avatar
Former Vendor
SERIES is a percentage of the width.It is not actual size.If you go wider in size ,the diameter will also increase.That is why there are different series.A 245/35/ will be the same overall diameter as a 285/30 will be.If you are still confused ,go to a tire mfg.website and it will explain the details to you.
Old Oct 6, 2006 | 03:00 AM
DHCrocks's Avatar
what he said....the series of a tire is the aspect ratio. it's a measurement of the sidewall height of a tire. the overall diameter of the tire is = the rim size + 2 (sidewall height).
The sidewall height is the aspect ratio x tire width (this is in mm and needs to be converted to inches).
here's a few sizes for you to compare.
for the front:
225/45/18 = 25.98"
245/30/20 = 25.79"
245/35/20 = 26.76"
255/30/20 = 26.03"<-----best choice
255/35/20 = 27.03"
for the rear:
245/45/18 = 26.69"
275/30/20 = 26.50"
275/35/20 = 27.58"
285/30/20 = 26.74"<-----best choice
285/35/20 = 27.86"
305/30/20 = 27.21"
Old Oct 6, 2006 | 10:03 AM
Red face I Get It!!
You guys rock! Thanks for the help. My problems have been solved. I will now leave you alone!
wuppiedog
Engine - Exhaust
Sep 6, 2015 12:07 PM
socalg35x
Aug 7, 2015 09:36 AM
Terry_G35
Aug 4, 2015 02:38 PM
bjo16
Aug 4, 2015 09:52 AM
newg37
Jul 26, 2015 09:32 AM
