Tire Size Question
Tire Size Question
Can i put 285's in the rear and 255's in the front. Or will i have a problem with rubbing or any other problems. I have 19x9 in the front and 19x10's in the rear so any knowledge is welcome
Re: Tire Size Question
i have a 245/35/20 setup in the front and
285/30/20 in the back, its been a little over a month with this setup and so far no rubbing and i still have a lot a clearance left between my wheels and fenders
Hey Bigsmasher, just wondering what your offsets are?
Black on Black 5AT Coupe
Premium, Aero, Splash guards, Navi
19" Axis Se7en Mods w/ Toyo FZ4s
350Z Duct
7 Wire Hypergrounding Kit
Aluminum Pedals
350Z Duct
Aluminum Pedals
You can with good safe offsets. As for mine I'm running 245/35/19 front and 285/30/19 rears. I had to roll my fenders to fit these wheels..
- Don't argue with idiots. They will bring you down to their level and beat you with experience.=P-
mine is 245/35/20 in the front and 285/30/20 with Pirelli tires and my rims are 20x9 and 20x10 but i've noticed that if i try to make a left or right turn going around 30-40ish then my tires cant take it and my "slip" signal will come on . Before with my stocks i could take a turn with 40 easy. I thought if i get a really wide stand with the 285 in the back that the handling would be much better but nothing beats your stocks
My Nismo 18s, beat my stock 18s all to hell. I have 245/40s in front and 275/40s in the back. Fronts are 8.5" 25mm offset. Rears are 9.5" 30mm offset. I have Dunlop SP9000s on them. Before changing your wheels, you must do your home work. I love the look and the handling of the setup that I have.
Lou
Lou
