Lightweight 19" vs OEM 18" vs OEM 17"
#62
Red Card Crew
Don't know about Indy but this is probably the reason for using those ballon tires:
Also Indy wheels are only 15" so they have to run a higher profile tire.
Inner and Outer Tires
On tracks that are more than 1 mile (1.6 km) long, where speeds are faster, NASCAR rules require that tires contain an inner liner. This is essentially a second tire mounted inside the first tire. It mounts to the rim and has its own separate air supply. If the outer tire blows, the inner tire is still intact, allowing the driver to bring the car to a controlled stop.
Originally Posted by G35_TX
Sure. Yea, a lot of these racers use low profile ghetto style tires for racing. LOL! If that was true, then you would see Indy cars or Nascar with really low profile tires and a large wheel.
You just proved you know nothing about racing. Again, why do MOST have larger sidewalls? WHY? I said why.
#63
These dont look like low profile ghetto race cars to me...
http://www.world-challenge.com/gallery/#
scroll through the gallery and define "ghetto" for me, please!
-sean
#65
on
Like I said, if wheels being large and tires being lower profile was a better thing it would be on there. But it is not. That is why you see SCCA all these miatas, etc with small wheels and larger tires.
If it was safety, then the Nascar tires wouldn't be as large as they are either. lol
#66
on
Originally Posted by Nismo G
No, you just proved that you know nothing about racing. Road racing, indy, and nascar are three way different racing classes. You cant even compare an open wheel indy car and a cts cadillac. Cant even compare nascar either considering they only drive in a circle, they dont need a strong sidewall tire thats why they use those huge sidewall slicks.
-sean
-sean
Again, this goes back to why the 350z on the track package has smaller wheels.
No, I proved my point. That is why professional racers do not use small profile tires.
If you look at those pictures, most of those wheel/tires are no more than max 18" in size on those cars. Like I said 19" is too much and is not for racing purposes.
#67
Red Card Crew
Not necessarily. You couldn't have low pro tires and FIT the safety systems required for the series. There is a difference inbetween the performance benefits of low profile tires AND RULES REGULATIONS for any particular race series. You don't get to run any tire/wheel combo in every race series. You should know this
#68
#69
Diameter might be true, but the overall mass is larger due to metal vs rubber. The bigger the wheel, the less performance you get.
Why do you think the 350z comes with smaller wheels on the performance models? lol.
#70
You proved nothing. So they run almost all the same wheel/tire on every car. Looks to be the same wheels too. I bet they don't have a choice. Coming from racing experience and trying 19s and 18s on cars, I know that 18s are better for racing. More flex, less hop over bumps, more stability. 19s are way to skinny on the G35 to race in.
Im just simply setting up an experiment at school to prove everyone that thinks the 19" wheel is better for acceleration wrong, but i cant do it without mathmatic evidence to back it up. Atleast on this forum. sorry if we are not talking about the same thing.
-sean
#72
IIRC, there was a thread discussing the difference between stock 18" vs stock 19" wheels. I was one of the first people to switch from the 18" to the 19" so I did quite a bit of research on it. The result I found out was that....
1) OEM 19" rims are lighter than OEM 18" rims by appx 3lbs.
2) OEM 19" Potenza RE050A tires are much heavier than OEM 18" Michelin Pilot Sport
3) Handling with the 19" is definitely sharper and has less roll.
4) 18" feels lighter on the feet and helps with acceleration more.
It's true that the 19" Rays are lighter than the 18" cast. It's also true that the OEM 19" rays actually have less rotational mass than most aftermarket 19" rims. Take a look at the lip design of the OEM 19", they are actually very similar to a 18" rims with lip extension to make them into 19" rims. This particular lip design helps reducing the rotational mass on the OEM 19" compared to traditional 'fat lip' design on aftermarket wheels.
I think with the right tires the OEM 19" are very very competent rims for performance purposes. OEM 19" with Toyo tires (245 front / 255 rear) would probably yield very good performance on the track) As it stands, the weight of the Potenza RE050A makes the weight saving from the forged 19" pointless compared to OEM 18". (Why Infiniti, Why!?)
#73
Red Card Crew
Thanks Sukairain. That about sums up my info as well as adding the lip info.
I just switched back to my oem 215-55-17s on stock wheels because of the snow. I noticed the accerlation is better as well as the gas mileage. But I don't know if it's because the 19s are heavier (I imagine they are heavier than the 17s/tires) or if the bigger dia rear tires are fudging my navi gas calculations.
I noticed the tire thing also when I was researching the wheel weights and tire weights. The RE050s are ROCKS! Would have been much better to go with the Michelin Pilots for the oem 19s. That would save 3-4 lbs right there!
#74
on
You know, the easiest test you can do to test this out right? I know it isn't very scientific, but it'll work. What you do is, get two tires (the OEM 18's and 19's), put it on an incline, at the top, and let them both roll down the incline and see which one rolls down faster. I did this way way back in College Physics Class and it works. The key here is that even though diameter are different on the tires, it'll give you an approximation as to which one has less rototational torque, or whatever it is called.
#75
