same tire size all around 19's
Old Jan 23, 2007 | 06:01 AM
Ferrarimanic360's Avatar
i just put some fuzion zri's on my coupe 19's and i put 245/35/19's all around, the tire shop said i shouldnt have any problems with doing that but when i was driving on the freeway the car swayed alot more than usual, it also wanted to pull to the right. Is this the cause of putting the same sizes tires all around? or do i need to do an alignment, and also what problems if any will i encounter as a result of doing this
thanks in advance
Ash
Old Jan 24, 2007 | 10:05 PM
bumppp
Old Jan 29, 2007 | 05:53 AM
lookin for some answerss
Old Jan 30, 2007 | 12:08 AM
ZeroGen's Avatar
Omega Enthusiast
Sounds like you need an alignment considering you mentioned the car is pulling to the right.
I would go with a staggered set up. IMHO it looks better.
Old Jan 31, 2007 | 05:15 PM
G35Bearcat's Avatar
It is unlikely that it is due to the same size tire all around. Start with with an alignment like the guy above mentioned. It is possible that the tire is causing this pulling though, if you were driving on a HWY that has grooves ground into the surface that are aligned with the direction of travel.
Old Jan 31, 2007 | 05:17 PM
Jeff92se's Avatar
Red Card Crew
^^^ +1. Could be a radial pull from one of the tires.
Old Jan 31, 2007 | 10:04 PM
what exactly is a radial pull?? thanks for all the replies guys
Old Feb 1, 2007 | 12:36 AM
Jeff92se's Avatar
Red Card Crew
http://www.tirerack.com/tires/tirete....jsp?techid=12
Old Feb 1, 2007 | 01:21 AM
GreenGoblin's Avatar
The goblin resurrection
I would def get an alignment it cant hurt it will only save the tread life
Old Feb 5, 2007 | 11:53 PM
superb16's Avatar
thanks in advance
Ash
I'm getting ready to mount coupe 19s on my sedan. I decided to go with 235/35 at the front and 245/35 at the rear. The way you have your car set up don't the rear tires look stretched more than the fronts?
Old Feb 6, 2007 | 12:57 PM
kay350gt's Avatar
As everybody has already stated, your alignment got knocked off by using different sizes... 40-50bucks at a shop should fix it
vitamin.v
Nov 7, 2019 06:10 PM
Footballmania32
19 Inch
Jun 2, 2018 07:31 AM
mryogi
Aug 14, 2015 07:58 PM
Jnm07
Aug 6, 2015 03:03 AM
CrazyLogic219
Jul 23, 2015 10:58 AM
