Will I need any adjustment to run coupe 19's?
Old Mar 22, 2007 | 10:23 AM
ron4row2's Avatar
Question Will I need any adjustment to run coupe 19's?
I have a 2004 sedan without any sport supension. I'm looking into purchasing a set of coupe 19's. My question is will I have to adjust the camber or can I just bolt the on? Also, I was looking at running 245/40/19 tires, will those fit without any rub?
Thanks
Old Mar 22, 2007 | 11:55 AM
Gilley's Avatar
They'll bolt right on with no modification needed. Camber kits are only if you lover the car.
Old Mar 22, 2007 | 02:16 PM
ron4row2's Avatar
So rubbing shouldn't be an issue.
Old Mar 22, 2007 | 02:17 PM
Gilley's Avatar
Only if you drop it a lot and install really wide tires. Stock size tires will be fine, especially on a stock suspension.
Old Mar 22, 2007 | 04:13 PM
ron4row2's Avatar
I'm not going to drop it. I'm going to leave it stock. I'm looking at 245/40/19 tires all around. Will that size work well or should I go with something else?
Old Mar 22, 2007 | 04:21 PM
Gilley's Avatar
I have 245/45/18's on my sedan. I would think the 40 series 245/40/19's will be fine.
Old Mar 22, 2007 | 06:17 PM
BadBoy06's Avatar
that would work or you may want to go with the stagger look? 225/245
8 inch and 8.5 so no issues there
Old Mar 22, 2007 | 11:32 PM
Gilley's Avatar
You bring up a valid point that I failed to consider. The 19 inch coupe wheels are 19x8 +30 front and 19x8.5 +33 rear, but according to the tire calculator, the 1/2 inch rim difference is negligible, so you can still run the same size tires all around.
http://www.rims-n-tires.com/rt_specs.jsp
mjfenix
Aug 17, 2017 05:49 AM
jimNC
Jul 25, 2015 05:47 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
netcbc
Jul 24, 2015 11:25 AM
Carlos_G358696
Jul 18, 2015 03:22 PM
