tire size question
Old Mar 29, 2007 | 12:26 AM
Ford F1's Avatar
tire size question
I have 18x10 +30 and 18x8 +29 GT7s for my coupe.
I plan to drop with 350z H techs or something along that amount (enough that a camber kit wouldn't be needed, but I might do it later on).
What size tires should I run? I don't want to roll the fenders, and if I drop it I figure a 285 will rub. I have noticed that the 40s up front look a little thin. Do many people run 245/45s?
The tires I have been looking at are 275/40/18 and 245/40/18 Falken 452s which are $600US shipped which I think is pretty darn cheap.
Any advice is appreciated.
Old Mar 29, 2007 | 12:43 AM
redlude97's Avatar
You should probably be okay with a 285/40/18 because your offset is relatively high at +30. I run a 285/35/19 on a 9.5" with a +30 and I clear without rubbing, so you should as well. 245/40/18 is the correct front tire size
vitamin.v
Nov 7, 2019 06:10 PM
Jnm07
Aug 6, 2015 03:03 AM
reaper76
Aug 5, 2015 10:13 AM
Popes
Jul 29, 2015 05:07 PM
CrazyLogic219
Jul 23, 2015 10:58 AM
