widest tires on oem 19's ?
Old Apr 10, 2007 | 10:09 PM
caseynrs3's Avatar
looking for info on the widest tires i can put on the oem 19's..
thanks
Old Apr 10, 2007 | 10:38 PM
nghiars's Avatar
ive seen 275 but heard it might not be safe...
Old Apr 10, 2007 | 10:46 PM
caseynrs3's Avatar
found a guy locally that has 245/40/and 275/40 se of pilots for sale, and at a good price, just wanted to see if that would be too wide on the stock 19's
Old Apr 10, 2007 | 10:47 PM
Andy2434's Avatar
Ouch! . . . 275 on a 8.5" rim? I think I have read that somewhere here on these boards. I would be very concerned at speed and travelling through the twisties on a set-up such as that. That might give "Railing It," a whole new meaning.
Old Apr 11, 2007 | 07:09 AM
redlude97's Avatar
The problem there isn't width, its height, you should be looking at 35 series sidewalls in those widths, but I don't recommend running anything wider than a 255 on the stock 8.5" wheels in the rear
Old Apr 28, 2007 | 10:08 AM
JOKER's Avatar
CLUB MODERATOR
I got 255 40 on my rear. And I think I should have gone 35 instead. Car feel kinda shaky on the corners at the high speed.
I'm gonna try calling tire shop see if I can change them on 255/35.
Old May 2, 2007 | 09:48 PM
Sam Siador's Avatar
I'm running 285/30 Bridgestone S03 on my ride!
Old May 2, 2007 | 11:51 PM
redlude97's Avatar
On the stock 8.5" wheel? Post up pics!
Old May 2, 2007 | 11:56 PM
MixturePinoy's Avatar
Would 255/35 be okay for the stock 18's?? Looks like I flattened both my rears the other day taking pictures in the woods. So now it's garage bound till I can get someone to tow it. but i'd like to go wider than whats on em as well.
Old May 3, 2007 | 12:12 AM
redlude97's Avatar
You'll want 255/45/18 or 255/40/18, 35 series is way to short. I would personally recommend the 255/45/18s as they will long be slightly taller than stock, rather than much shorter than stock
Old May 10, 2007 | 02:48 PM
rizoyalo's Avatar
i'm thinking about 255/40 on the rear, and 235/40 on the front with the OEM 19 wheels. This should be a good fit, right? Just want to make sure before ordering them.
Old May 15, 2007 | 11:11 AM
kuhntar's Avatar
Here is the math to figure out how wide of tires you can put on your rims.
245/40R19
take the width (245) and multiply it by the aspect ratio (40)
245 x .40 = 98
So a compareable tire would be 275/35
275 x .35 = 96.25
Now when you change your tire size it will throw off you speedomoter, you can check out this website to see how much of a difference.
http://www.paspeedo.com/calculator.htm
Old Oct 21, 2007 | 11:10 PM
fredrik94087's Avatar
Answer!!!
I wish someone had done this before with success and told me about it.
I hope the information is not too late.
Just a small intro...I have modified the hell out of a car I used to have...I owned a 2004 G35...then I got an EVO VIII (sorry to trade it in)...and traded it for a 2005 G35.
I really missed the handling and comfort level in the EVO. I wasn't sure what I was going to do when time came to replace the tires on the G.
I had the local place dry fit 265/35/19s. These tires are just 0.4 inches shorter than stock...or just 0.2 inches shorter per sidewall. I was a bit concerned on how they would fit. They don't really bulge out as I thought they would, and now I wish I had tried on the 275s because the 275/35 height would be closer to stock. But, they were not in stock, and I was in a hurry.
Up front, the 245/35/19s fit PERFECTLY on the stock 19" rims.
I understand that the front rim is just 8" while the rear is 8.5", but you can put 245/35 up front AND 265/35 in the rear.
Ask the shop to fit 275/35 for you and see how it looks. As far as I can tell, it may just fit.
The RE050A requires a 9" rim for the 265 and for the 275 as the minimum width. Since they both have 9" as the minimum, I am inclined to believe that the 275 will fit nicely as well.
I wish I had more grip in the rear or less anti-sway bar in the rear. I have more bite from the tires, but as I put the power on through the turn, the rear wants to come loose, and letting off the gas would not be a good idea because the rear would definitely come around.
I am riding on the Tanabe Sustec front and rear anti-sway bars.
If anyone here decides to go the anti-sway bar route, just get beef up the front one and leave the one in the rear as it is.
When the 265 wares out, I will try to fit a 275 and see if it sits the same on the rim. If the 275 doesn't give me enough balance through a corner, I will switch the rear anti-sway bar back to stock OR, I may want to get an adjustable one for the rear.
Good Luck!
Old Oct 22, 2007 | 12:13 AM
Beebo's Avatar
i have 245/40/19 allround and plan on 255 on the rears next time
i wouldnt go more than 255
Old Oct 22, 2007 | 12:28 PM
265/35/19 fits fine on OEM 19" rims
Just what the title says. I have it on right now and I do push the car through turns. I honestly feel that I can go one size wider to 275/35 and still be okay.
For anyone who wants to go 265/35 on OEM 19", don't worry...it fits and it doesn't look like it bulges at all.
I'll have to take a few pictures and somehow post them here for all of you to see.
245 in the front and 265 in the back...no problem.
Cheers!
