19x9.5 +30 with 19x10.5 +28 Tire choice? Rubbage?
Old May 3, 2007 | 09:13 PM
nellyT's Avatar
Ok so I got some a set of volk gts on order, 19x9.5 +30 in front and 19x10.5 +28 in the rear, but I'm still unsure of the size I can get away with. I ordered the wheels from Greg of Injected Performance and he assured me the offset will work fine.
He also recommended me to go with 245/35 in front and 275/35 in the rear but I was wondering if I could go wider without rubbing, just for some extra rim protection. Maybe 255/35 in front and 285/35 in the rear, i think that actually matches the OE diameter better but I'm worried that I'll be rubbing one something. It's going on a 05 coupe with stock suspension.
Any opinions?
Old May 3, 2007 | 10:58 PM
ATL_Red_G35's Avatar
the front is going to be okay. The rear may rub.
I had maya STM +29 on 285 and they rubbed. I had to roll the fender a lil. But it's definitely worth the safety. At least run 255 on the Front.
Old May 3, 2007 | 11:00 PM
ttrank's Avatar
Grocery getter
I would do a 285/30 in the rear to keep them closer to the same diameter so your VDC does not flip out.
Old May 3, 2007 | 11:10 PM
nellyT's Avatar
wouldn't the 285/35 actually be closer to teh stock diameter?
Also can I use teh stock TPS and valve stem in the volks? I tried to search this but didn't come up with much
Old May 3, 2007 | 11:44 PM
ttrank - 285/35 rear doesn't affect the VDC sensor at all.
Nelly, I think you can use the TPS, but requires a lil modification I last read. Contact the wheel vendor to see if they can help you.
Chris from F1Motorsports can help you with that. He's a great guy.
Old May 4, 2007 | 12:02 AM
alphamatt's Avatar
i got the same size wheels runnin 245/35 and 275/35 rear with about a 1.2ish drop and i had to get my fenders rolled, but it also depends on the tire, some are more cambell's chunky than others.
Old May 4, 2007 | 12:10 AM
nellyT's Avatar
hey alphamatt, are you using the stock tps by any chance?
Old May 4, 2007 | 12:21 AM
nghiars's Avatar
on stock suspension for a coupe.. 285/35 wont even come close to rubbing.. theres like a 2inch gap from the tire to the top of the fender with my 275/35/19
Old May 4, 2007 | 01:16 AM
alphamatt's Avatar
took the tpms out, i hated it anyway, whenever its coldand my tires depressurize it goes off and annoys the hell out of me.
Old May 4, 2007 | 02:56 AM
Calvin's Avatar
Overglorified Altima
unless you're slammed, 275/35 on a 10.5" wheel won't rub. the fronts will be fine.
Old May 4, 2007 | 08:16 AM
panda007's Avatar
hi. i think those offsets are quite on the conservative side... imho.
i have 255/40 front with 285/35 rear. when the car was slammed about 1.5" drop, the rear rubbed. i needed to roll/cut the fender lip.
bu villain
19 Inch
Nov 15, 2015 09:23 PM
Big C
19 Inch
11
Oct 3, 2015 05:11 AM
netcbc
Wheels & Tires CDN
Sep 24, 2015 09:53 AM
Popes
Jul 29, 2015 05:07 PM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
