Replacing all 4 tires for 1 damaged tire?
Old May 17, 2007 | 03:53 AM
empfl's Avatar
As the title says, do you need to replace all 4 tires, if say the sidewall is damaged for one tire and needs to be replaced. About 7k miles on the tires so far. Is it really neccessary to get a full set? or can I slide it by with just one fresh tire.
Old May 17, 2007 | 08:52 AM
kvangil's Avatar
+1. Just replace the bad one. At most, I'd replace the 2 that are on the same axle, if you're afraid of inconsistent wear between the two tires.
Old May 17, 2007 | 11:58 AM
g35rcr's Avatar
i always replace in pairs...
Old May 17, 2007 | 01:02 PM
dudeimjohn's Avatar
according to your signature, you don't drive a G35X, so you don't have to replace all four when you replace one. take it to a tire shop and have them measure the tread depth and compare to a new tire. i believe if the difference is less than 1/10 you dont' have to replace in pairs either. what i know is that the lsd will have a hard time determining if the tire is slipping due to the different diameters/spin rate of the tires with different diameters. its cheaper to replace a tire than to replace the lsd later.
Old May 17, 2007 | 01:06 PM
hai109's Avatar
Its all depends on how old the tires are...If the tires are below 40% then I would change both tires...If the tires are fairly new...I would replace just one...
Old May 17, 2007 | 04:25 PM
empfl's Avatar
thanks for all the help guys..
Old May 17, 2007 | 04:55 PM
joedaddy1's Avatar
if u have a sedan, just use ur spare for now.. till the others get worn.. and replace all 4
Old May 17, 2007 | 05:02 PM
hai109's Avatar
^^^Spare are only designed for temporary cases...If you look on the tire it has a speed rating...You should go over a certain speed limit. If you wear the spare down you will need to replace that too and the new tire...
Old May 17, 2007 | 06:38 PM
bocatrip's Avatar
The Coupe can't really use the temp for other than emergencies. The 06 and earlier sedans can use the optional full size spare.
Old May 17, 2007 | 10:57 PM
hai109's Avatar
The OP has a coupe...Besides...I wouldn't use the spare to roll on...
Old May 17, 2007 | 11:31 PM
Chrlesmd's Avatar
Agreed.
Old May 18, 2007 | 12:22 AM
ttrank's Avatar
Grocery getter
I try to always replace mine in pairs.
vitamin.v
Nov 7, 2019 06:10 PM
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
bu villain
19 Inch
Nov 15, 2015 09:23 PM
bTanz
Oct 15, 2015 02:31 PM
itschuckster
Jul 25, 2015 08:07 AM
