is it safe?
Old Jan 5, 2004 | 10:39 AM
retret's Avatar
is it safe?
is it ok to put 275/40/18 on an 18 x 8.5 rim? if its not I would probably get 255/45/18 for the rear and 235/45/18 for the front..thanks.
Old Jan 5, 2004 | 11:18 AM
ducatiguy's Avatar
Premier Dough Slapper
Re: is it safe?
For all of you who keep posting is it ok, or is it safe, or can you, install tire X on rim width XX, why don't you just see what the specs for the tire in question are? I don't mean to sound rude, but it's such a basic and simple task, that seems to be always overlooked.
Most tire manufacturers (well at least any worth putting on a rim and the road) will state what rim width each tire will work within. Its thats easy!
For example, with most 275/40-18 tires, they can be used on rims from 9" to 11" wide, with 9.5" being the industry standardized measurement. So would I put that on a 8.5" rim, no.
With 255/45-18 tires, the majority are designed to work on 7.5" to 9" wide rims with 8" being the industry standardized measurement. So this one I would consider.....
"See, the problem is that God gives men a brain and a *****, but only enough blood to run one at a time."
Old Jan 12, 2004 | 05:48 PM
ryoken's Avatar
Re: is it safe?
TireRack, too, includes specs for most of the tires they have in their online catalog.
seagrasser
May 3, 2022 09:43 AM
jeffbdye
Jun 1, 2018 03:51 PM
yosip1115
16
Sep 28, 2015 04:14 PM
Terry_G35
Sep 10, 2015 08:17 PM
