Recommended Rim/tire sizes for coupe
Old Jan 6, 2004 | 05:37 PM
EvolutionGSR's Avatar
Anyone have any recommendations on what rim/tire sizes for aftermarket i should be getting? for sure they will be 19" rims, but im debating 9 in front 9.5 in back, or will i be able to fit 10 in back? if i get 10 in back will i be able to fit 9.5 in front? will i be able to have 40 or 45 tires still? Also im not yet planning on lowering the car, but if i do it will be with coilovers and not more than 1" drop.
Life is hard, but its harder when you're stupid.
www.1911forum.com
www.calguns.net<P ID="edit"><FONT class="small"><EM>Edited by EvolutionGSR on 01/06/04 02:43 PM.</EM></FONT></P>
Old Jan 6, 2004 | 06:01 PM
Meatshackle's Avatar
Deep Sea Moderator
Re: Recommended Rim/tire sizes for coupe
I don't think you'll be able to go 10" in the back with 40 or 45 series tires and lower the car without some fender modification. I also don't think you'll be able to go 9.5 in the front with a 1" drop. Someone with more knowledge/experience might disagree with me, I'm just reciting what I've read.
Russ
Black 6MT Coupe
Jax, FL
PS2 and Headrest thread
Old Jan 6, 2004 | 06:32 PM
so would 9.5 be better in back? or i was also thinking about going 9 all the way around with a different offset....?? any other opinions/recommendations? Also what offsets should i be using for the nice lip in the back?
www.1911forum.com
www.calguns.net<P ID="edit"><FONT class="small"><EM>Edited by EvolutionGSR on 01/06/04 03:35 PM.</EM></FONT></P>
Old Jan 6, 2004 | 06:53 PM
RacingDynamcs's Avatar
perfect tires sizes for the g35's are 265 all around ... it will make for very balaned car feel.
*pipes +15rwhp
Old Jan 6, 2004 | 07:30 PM
Dynamics- would that mean i should use a 9" wide rims all the way around?
www.1911forum.com
www.calguns.net
Old Jan 6, 2004 | 07:46 PM
Carlos3186's Avatar
no no no u deffently do not want to do that on a coupe. that would be very bad and it would throw of the VDC.
the coupe requares a stagered set up. You should have no problems putting a 9.5 in the front and a 10 in the back but u will not want to run a 40 or 45 series tire becuase that will throw off ur speedo and will also most likly not fit on a lowered G. You are best to run a 35 siries tire. i would recoment running this 245/35/19 up front and then run 275/35/19 or 285/35/19 in the rear. that will be perfect. good luck
<a href="mailto:Carlos3186@hotmail....otmail.com</a>
Old Jan 10, 2004 | 01:14 AM
265 allround is race spec ... what the heck you talking about being bad...
*pipes +15rwhp
Old Jan 10, 2004 | 02:08 AM
Ok so I've been talking to a few people and have finally decided that i would go with 19x8.5 with 255/35 in front and 19x9.5 275/35 in back. Potenza S03 would be tires of choice. Does anyone know what the XL means on the tire sizes on the bridgestone site?
Another question. For now, im NOT going to lower the car. Hypothetically, if I stick 255/40 275/40 on the wheels, other than my speedo, will anything else be off? It would be to fill the wheel gap a little without having to lower the car, to preserve a little bit more of the ride, and a little extra rubber between the metal and the asphalt (scared to bend rims). I know the ride height will be slightly higher. Anyone have input on this?
www.1911forum.com
www.calguns.net<P ID="edit"><FONT class="small"><EM>Edited by EvolutionGSR on 01/09/04 11:11 PM.</EM></FONT></P>
Old Jan 10, 2004 | 08:22 AM
Micah's Avatar
The car would look like a 4x4 with bigger tires. I wouldn't like that.
Old Jan 10, 2004 | 11:23 AM
Deep Sea Moderator
Stock front diameter = 25.97"
245/35/19 = 25.75"
255/35/19 = 26.03" (not much difference)
255/40/19 = 27.02" (basically a .5 inch lift and about 5 % speedo error)
Stock rear diameter = 26.68"
275/35/19 = 26.58"
275/40/19 = 27.66" (another .5 inch lift in the back)
I'd be worried about the 255/40s rubbing the front fender. I think some guys with 20s and 255s had to change for that reason. The car will look slightly raised but the sidewall heights for stock and the 40 series mentioned above are identical.
Russ
Black 6MT Coupe
Jax, FL
Old Jan 12, 2004 | 10:22 PM
AirSplat's Avatar
You won't really be able to fill the wheel gap. This guy just got 20's and he still has a nice gap all the way around.
https://g35driver.com/forums/showfla...&sb=5&part=all
It looks really good and it closes some of the gap, but there's still a gap. I don't think it'll be possible to completely close it off. Especialy if you don't drop it. But then you have the problem with tire rub if you don't roll the fenders. It's a tough choice. But as tentra mentioned, it'll close the gap a litle.
'04 G35 6MT Ivory Pearl
K&N Drop In / Stillen Grounding Kit
Borla Headers/Dual Cat-Back Exhaust
Nismo Front Bumper/Side Skirts
Impul Rear Bumper/Spoiler
AirSplat.com for AirSoft Guns!
marsman328
Northern California
Aug 11, 2015 07:29 PM
Detailed Image
Jul 29, 2015 08:42 AM
multimut
Canada
Jul 26, 2015 08:43 PM
